annoying fault
  • petehall347
    • Jan 2015
    • 4448
    annoying fault
    hundreds of channels on the tv but nothing worth watching ..
    any suggestions ?
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    Re: annoying fault
    Hardcore midget clown porn, or maybe one of those religious channels.
    • petehall347
      • Jan 2015
      • 4448
      Re: annoying fault
      where is the like button ?
      • RukyCon
        A Fake Rubycon
        • Jan 2017
        • 816
        Re: annoying fault
        i have not touched a tv in a long time
        I'm not a expert, I'm just doing my best.
        • dskall
          • Oct 2016
          • 2905
          • usa
          Re: annoying fault
          I think that's why we fix TV's. Much more interesting behind the tv than in front.
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8351
            Re: annoying fault
            any suggestions ?
            quit fastening your coax around the sewer pipe. Maybe you get less $h*t coming out of your telly!
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              Re: annoying fault
              +10..... I repair TVs but don't watch any TV shows.....More a NETFLIX person...
              • Rictech
                Panasonic SA-MAX770PU SMPSU board fault....
                by Rictech
                Hello everyone. 😀
                As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
                Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
                Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
                This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
                There are no devices that have exploded or otherwise show signs...
                08-26-2024, 01:05 AM
              • howardc64
                Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                by howardc64
                • Prior owner tried a replacement main board. No difference.
                • Samsung 2x red blinking standby LED = panel fault
                • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                07-19-2025, 10:54 PM
                ESR meter came to the rescue again today with a PLC I/O card fault
                I have been having a fun time at work with two pieces of equipment that had shorted components or shorted component cables to machine frame
                I would check what my multi meter was telling me about how many ohms I getting with the multi meter was telling versus the ESR was telling me about weather or not it really was a short to machine ground or not
                One note at first we thought that it might be a bad I/O card or a malfunction PLC including me as well but I thought I would try and see if removing the I/O cables would make a difference or not and this time it did make a difference...
                12-18-2023, 08:17 PM
              • cazi1001
                Strange fault on Lenovo ThinkPad E14 Gen. 2
                by cazi1001
                I have a strange fault with a Lenovo ThinkPad E14 G2 (Board No. NM-D011 Rev. 1.0).
                The first Problem, which I fixed already, was a dead TPS65944AD (USB Type-C) controller. After I fixed this fault, all functions working fine and the notebook run very well with the charger and battery.
                On the next day, I tied to start the notebook with the battery, but nothing happened. I started with the charger and on windows, I saw, that the battery was empty. And this was nearly impossible, because the battery was charged. I disconnected the battery and found out, that the board...
                03-24-2024, 04:16 AM
              • r2digital
                Harmon Kardon AVR340 no sound on 4 channels
                by r2digital
                Hello, i had this amp sitting in the closet knowing that none of the channels were working. After taking it all apart i found 4 bulging main filter caps so i went ahead and replaced those with low ESR kmet caps. However after doing this it only restored sound to Surround L, Surround R, and Center channel. The main speaker fuse on the transformer F905/F906 keeps blowing so i decided to remove all of the transistor's on those 4 channels and measure them. All transistors appear to be in good working order(turned receiver on with none of them installed and fuse still blows). Checked dual emitter resistors...
                03-09-2024, 01:33 PM
