Samsung ps50b430p2w vertical lines and problems
  • Anst11
    • Jan 2017
    • 3
    New to the forum and very happy to have found a tech community to find some help. Totally new to all this so bear with me I know nothing about tv's anatomy as yet.
    I have a Samsung ps50b430p2w 50 inch plasma, randomly started showing 2 vertical black lines about 2/3inches in width all the way down the screen. One on the left hand side of the screen, one on the right.
    I got researching and evidence pointed to ribbon cables being loose and or damaged. I took the back off and checked firstly the horizontal ribbon cables and they were fine. I couldn't find the vertical ribbon cables (I'm guessing I have to take it apart more??!!)- I am guessing these vertical ribbon cables are attached to the buffer board located at the bottom of the screen behind some other boards I will have to take off?
    Anyhoo, before realising this I fiddled with another ribbon cable that controls left hand half of the screen. This promptly made it worse so I now have these two black strips and some other interference too on that left hand side.
    It's so damn heavy I don't want to to take it to a repair shop and no one will come out so I'm treating it as a project. I got it for free so nothing to lose...
    Any ideas?
    Any help would be most appreciative.
  • Anst11
    • Jan 2017
    • 3
    Re: Samsung ps50b430p2w vertical lines and problems
    anyone?
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Image of the fault. Come on we aint physcis !
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        psychic...
        • Falki
          Colorful LCD Vertical Lines on Samsung ue55es8090
          by Falki
          Hello there, ive recently found an older 55inch Samsung SmartTV.
          A similar issue has been posted as well but also with no actual response ...
          08-12-2025, 04:19 AM
        • Stanley1843
          by Stanley1843
          06-29-2024, 11:54 AM
        • pni
          LG 49uf695v vertical coloured lines
          by pni
          Hi guys…I need your help. My cousin ask me to fix her tv. The tv when I went to pick up showed 3 horizontal black line. So I know it was a bad panel issue but I could try to fix with the tape method so I said her I could fix easy. When I come back to home, I turned on the tv and now the tv show vertical line colored….and the problem is that I unplug the ldvs cable, first the right side then the left side I still have the lines. The lines never disappear. When the right side is plug in I don’t have nothing on the screen only this vertical lines, when the right side is unplugged I have picture...
          11-14-2025, 03:15 AM
        • x_orange90_x
          Samsung UN46C8000XFXZA vertical bars/horizontal lines
          by x_orange90_x
          I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
          The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
          09-04-2023, 12:09 PM
        • polaro
          Thin stable coloured vertical lines on Samsung UN65NU6900FXZC come and go
          by polaro
          Greetings,
          I've bought a used Samsung UN65NU6900FXZC LED TV. It worked fine for some time and then developed, at first, a single very thin (1 pixel) vertical stable blue line, from top to bottom, close to the left edge of the screen. Now it's 3 lines on the left. When I connect HDMI sources the number of the thin lines grow. After disconnecting and cold discharging I am back to 2 lines. The lines disappear at a rate of 15-20 minutes per line. So it does not look like a damaged LED panel. Any advice? Thanks...
          08-27-2022, 08:46 AM
