Samsung ps50b430p2w vertical lines and problems
  • Anst11
    • Jan 2017
    New to the forum and very happy to have found a tech community to find some help. Totally new to all this so bear with me I know nothing about tv's anatomy as yet.
    I have a Samsung ps50b430p2w 50 inch plasma, randomly started showing 2 vertical black lines about 2/3inches in width all the way down the screen. One on the left hand side of the screen, one on the right.
    I got researching and evidence pointed to ribbon cables being loose and or damaged. I took the back off and checked firstly the horizontal ribbon cables and they were fine. I couldn't find the vertical ribbon cables (I'm guessing I have to take it apart more??!!)- I am guessing these vertical ribbon cables are attached to the buffer board located at the bottom of the screen behind some other boards I will have to take off?
    Anyhoo, before realising this I fiddled with another ribbon cable that controls left hand half of the screen. This promptly made it worse so I now have these two black strips and some other interference too on that left hand side.
    It's so damn heavy I don't want to to take it to a repair shop and no one will come out so I'm treating it as a project. I got it for free so nothing to lose...
    Any ideas?
    Any help would be most appreciative.
  • Anst11
    • Jan 2017
    Re: Samsung ps50b430p2w vertical lines and problems
    anyone?
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Image of the fault. Come on we aint physcis !
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        psychic...
        • Stanley1843
          Screen Display Vertical Multicolor Lines
          by Stanley1843
          Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
          06-29-2024, 11:54 AM
        • x_orange90_x
          Samsung UN46C8000XFXZA vertical bars/horizontal lines
          by x_orange90_x
          I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
          The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
          09-04-2023, 12:09 PM
        • polaro
          Thin stable coloured vertical lines on Samsung UN65NU6900FXZC come and go
          by polaro
          Greetings,
          I've bought a used Samsung UN65NU6900FXZC LED TV. It worked fine for some time and then developed, at first, a single very thin (1 pixel) vertical stable blue line, from top to bottom, close to the left edge of the screen. Now it's 3 lines on the left. When I connect HDMI sources the number of the thin lines grow. After disconnecting and cold discharging I am back to 2 lines. The lines disappear at a rate of 15-20 minutes per line. So it does not look like a damaged LED panel. Any advice? Thanks...
          08-27-2022, 08:46 AM
          09-07-2024, 05:50 AM
        • Anonmis
          Samsung 55" UN55JS9000 - Pink vertical lines due to chipped LCD panel?
          by Anonmis
          Hello all, I was recently repairing my Samsung 55" UN55JS9000 tv from the common burnt backlight LED's and cracked light guide panel issue. After replacing the LED's and putting the TV back together, I tested the tv and all I was getting was sound but no image. Somewhere along the way (could be related to the next issue) the T-Con board became damaged and after replacing it I have made a little bit of progress but now have bright pink vertical lines and still no image.
          The bigger issue .... I took the TV apart again and realized that I likely didn't sit the LCD panel correctly...
          12-01-2023, 04:31 PM
