Vizio Vf551xvt- eeprom
  • Jmsmbry
    • Jan 2017
    • 24
    When replacing an eeprom for this tv, can the new be installed or does it have to be programmed first? What happens if it is not programmed?
  • SLK001
    • May 2014
    • 264
    Re: Vizio Vf551xvt- eeprom
    It must have the correct program already installed.
    It's like having a body with no brain - nothing happens.
    • Agent24
      I see dead caps
      • Oct 2007
      • 5035
      • New Zealand
      Depends what you mean. Are you buying a blank EEPROM brand new from Digikey or something, or one specifically for your TV, from a place like ShopJimmy that would sell it pre-programmed?
      -David VanHorn
      • Jmsmbry
        • Jan 2017
        • 24
        I don't have a way to program eeprom. Any sources that sell them programmed for specific tv models?
        • Agent24
          I see dead caps
          • Oct 2007
          • 5035
          • New Zealand
          Yes, places like ShopJimmy sell programmed EEPROMs. You may also be able to find them on eBay or such.
          Do a Google search for EEPROM + your board's model number.
          -David VanHorn
          • edgarmg15
            Damaged EEPROM on TV Vizio E320-A0
            by edgarmg15
            Hi everyone
            I´m trying to repair a TV Vizio E320-A0 that I found in the street
            The symptoms are it doesn't respond with remote or buttons, the LED indicator is always off and also there is no image on the TV.
            The power supply board works fine (I probed the terminals with my multimeter) but in the main board the EEPROM doesn't works correctly because the voltage on the pins doesn't match with the parameters of the datasheet.
            So, I´m going to replace the EEPROM with a new one, but the problem is that my programmer (CH341a)...
            11-19-2022, 03:46 PM
          • Jane
            SIO KB9022QD - must be programmed before replacing ?
            by Jane
            Anyone knows if ,these days,new KB9022QD must be programmed when replacing faulty SIO in Acer Aspire 3 (dh5jv la-g021p Rev:1) ?
            02-07-2024, 07:57 AM
          • TechGeek
            DTK PAM-0055I - Need an EEPROM programmed
            by TechGeek
            Not sure if this is the right place for such a request. If not, please move to the appropriate place.
            I've got a DTK PAM-0055I (zero zero five five eye) motherboard whose flash BIOS has been completely and totally trashed. Someone had set the EEPROM voltage to +12V and fried the Winbond W29EE011-15 EEPROM. (I'll make sure that that won't happen again by snipping the +12V pin off of the responsible configuration header.)
            Anyways, is it possible that I could have someone program a Winbond W29EE011-15 EEPROM with a BIOS image for a DTK PAM-0055I motherboard?...
            07-15-2022, 06:04 AM
          • SidneyCanadas
            93C46 and 93C56 EEPROM
            by SidneyCanadas
            I tore apart my instrument cluster for my 2008 Toyota Corolla made in 2007 in Cambridge, Ontario, Canada and pcb location: IC6=EEPROM is a surface mounted device with part # of 93C46W7, some claim the EEPROM out of a Camry part # 93C56 will allow odometer to roll over 299 999 KM or miles. The data sheet for both is below:
            https://cdn.badcaps-static.com/pdfs/...c6e42b20d3.pdf 2
            Anyone know if the Camry one will work on my Corolla?. And which EEPROM reader/writers do you all recommend I purchase that will allow me to read the old values of the old...
            06-14-2023, 01:16 PM
          • x_orange90_x
            Replacing backlights in Vizio V755-J04
            by x_orange90_x
            I've had this monster for several months as I've hesitated to order backlights for it. Finally did order them and they are due to arrive tomorrow. Besides having ample space to work, are there any recommendations for working on such a massive screen? Should I remove the panel by myself or would 2 people be a better choice? I bought the double-cup suction cups from Harbor Freight and have been using them for the last few repairs on smaller screens. They are far superior to the single cup orange ones I used previously that would often let go without warning 😱.
            I have not replaced...
            12-03-2024, 07:03 AM
