SIO KB9022QD - must be programmed before replacing ?
  • Jane
    • Aug 2010
    • 190
    Anyone knows if ,these days,new KB9022QD must be programmed when replacing faulty SIO in Acer Aspire 3 (dh5jv la-g021p Rev:1) ?
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Yes,needs to be programmed
    • Jane
      • Aug 2010
      • 190
      Can you please recommend a good programmer?
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        SVOD/Vertyanaov
        • WTFRules!
          • Feb 2023
          • 35
          • Argentina
          Can KB9022Q D be programmed with CH341A and Neoprogrammer? Thanks
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Yes but not always reliable.
            • WTFRules!
              • Feb 2023
              • 35
              • Argentina
              Thanks! I´ll tinker with it when parts arrive and post results.
              Have a good one
              • WTFRules!
                • Feb 2023
                • 35
                • Argentina
                Have a good one
                OK, I can confirm that with CH341B and NeoProgrammer (MAlware aside) the KB9022Q D is 100% programmable.
                Hope this helps to anyone looking the same as I did.
                Have a good one.​
                • Reintar
                  Dell Inspiron 15 7567 (LA-D993P) - No power after replacing blown inductor and shorted mosfet advice needed
                  by Reintar
                  First of all, I'd like to mention that I'm a novice when it comes to laptop repair, although I do have some experience with soldering.
                  One day, my laptop experienced a severe stutter, and after rebooting, it failed to boot into Windows. I decided to disassemble it and found that the PL900 component was blown. Later, I came across a post (https://www.badcaps.net/forum/troubl...error%E2%80%99) with the same problem, where...
                  08-30-2024, 06:13 AM
                • DeXXter
                  Replacing SOC SRK08 clean me needed?
                  by DeXXter
                  Hello, so I replaced a soc SRK08 (i3-1115G4) on a hp 14-dq because the 1.8v power supply was shorted and the pch was gone and I installed a SRK05 (i5-1135G7) that I had at hand. And I was wondering if a clean me region is needed after replacing the chip, I usually do this on laptops with separated pch, but with a soc (cpu and pch together) I have no idea. Normally I wouldn't ask this, but I have only the motherboard, no screen nor the adapter, and after I fix this I have to send it to another region so if someone knows about this, some help would be apreciated.
                  Note: After doing all...
                  11-19-2025, 03:16 AM
                • competition
                  Replacing capacitors in Evga PSU
                  by competition
                  I have Evga G2 1300w and I want to replace all the electrolytic capacitors because PSU is already 12+ years old and I want to give it more life before any capacitor does damage. There are no blown capacitors, but I want to protect myself by replacing them with new ones as a precaution. And now comes the main problem. I have 5 pieces of Bulk (I think they are KZE) 16v3300uf with dimensions 10/35/5, but I can't find them in that size, only 12.5/35/5.I have one KY 16v1000uf 8.5/19/3.5, one KY 16v220uf I think it is 6/13/3.5 but it is in holes of pitch 5 I have 4 pieces of KZE 16v2200uf with dimensions...
                  11-14-2025, 11:12 AM
                • doivaythoiem
                  Need help with replacing the 12th generation CPU on a gaming laptop.
                  by doivaythoiem
                  Status: I have a 12th generation Acer Nitro laptop with the main code HH514 LA-L973P REV 1A and the CPU is faulty. I replaced a CPU from an Acer mainboard of the same type and it worked, but the CPU had an error and couldn't enter Windows. Next, I replaced a CPU from a Dell laptop that was still working but had a VGA error. After replacing it, I flashed a new bios from the Acer manufacturer, but the machine still couldn't work. Can someone answer this question? Thanks.
                  11-06-2025, 01:29 AM
                • madscientist750
                  Replacing electrolytic caps by solid caps on old motherboards
                  by madscientist750
                  I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
                  I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
                  I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.
                  10-19-2025, 06:10 AM
