DTK PAM-0055I - Need an EEPROM programmed
  • TechGeek
    Computer Geek
    • Jan 2015
    • 2254
    Not sure if this is the right place for such a request. If not, please move to the appropriate place.
    I've got a DTK PAM-0055I (zero zero five five eye) motherboard whose flash BIOS has been completely and totally trashed. Someone had set the EEPROM voltage to +12V and fried the Winbond W29EE011-15 EEPROM. (I'll make sure that that won't happen again by snipping the +12V pin off of the responsible configuration header.)
    Anyways, is it possible that I could have someone program a Winbond W29EE011-15 EEPROM with a BIOS image for a DTK PAM-0055I motherboard? I'll supply the EEPROM IC and BIOS image when ready.
    Thanks in advance.
    Permanently Retired Systems:
    Kooky and Kool Systems
    sigpic
  • piernov
    • Jan 2016
    • 4437
    • France
    Re: DTK PAM-0055I - Need an EEPROM programmed
    Just buy a TL866II, always comes in handy. Supports almost every BIOS ROM ICs you'll encounter from 40 years ago to today.
    • SidneyCanadas
      93C46 and 93C56 EEPROM
      by SidneyCanadas
      I tore apart my instrument cluster for my 2008 Toyota Corolla made in 2007 in Cambridge, Ontario, Canada and pcb location: IC6=EEPROM is a surface mounted device with part # of 93C46W7, some claim the EEPROM out of a Camry part # 93C56 will allow odometer to roll over 299 999 KM or miles. The data sheet for both is below:
      https://cdn.badcaps-static.com/pdfs/...c6e42b20d3.pdf 2
      Anyone know if the Camry one will work on my Corolla?. And which EEPROM reader/writers do you all recommend I purchase that will allow me to read the old values of the old...
      06-14-2023, 01:16 PM
    • dmccul2698
      Pioneer DEX-P99rs "No EEProm " diagnostic code.
      by dmccul2698
      Hello, My head unit developed strange behaviors so I ran the built-in diagnostic package which returned "No EEProm". The service manual says there is no EEProm connected. I approached Pioneer and they said to swap out the DSP board. All said and good but the DSP board is $860 USD. I am hoping someone can help me
      1). Understand the schematic and check the connections between the EEProm and DSP
      2). Check the functionality of the EEProm
      I don't know if this is the unit's problem but it's a place to start.
      I have little to no electronic experience...
      04-08-2024, 05:32 PM
    • Biruslapio
      Reprogram Philips 32PFL3008D Winbond EEPROM with ATMEGA328P
      by Biruslapio
      I've shearched before posting this, and found dozens of different ways to hook up multiple types of EEPROM to an Arduino Uno, so I do not know which one is correct.
      I need to learn this so I ended up with a Philips TV 32PFL3008D which has corrupted memory, the IC is U402, 25Q64FVSIG, I have the 3MB .bin file, how to hook up an ATMEGA328P to this memory and what code do I need?...
      12-03-2021, 08:33 AM
    • edgarmg15
      Damaged EEPROM on TV Vizio E320-A0
      by edgarmg15
      Hi everyone
      I´m trying to repair a TV Vizio E320-A0 that I found in the street
      The symptoms are it doesn't respond with remote or buttons, the LED indicator is always off and also there is no image on the TV.
      The power supply board works fine (I probed the terminals with my multimeter) but in the main board the EEPROM doesn't works correctly because the voltage on the pins doesn't match with the parameters of the datasheet.
      So, I´m going to replace the EEPROM with a new one, but the problem is that my programmer (CH341a)...
      11-19-2022, 03:46 PM
    • acedogblast
      by acedogblast
      11-02-2024, 05:13 PM
