LG Plasma 50PM9700 - same old double click & no start
  • JDMugenBB1
    • Jan 2017
    • 20
    I'm new to the forum and trying to narrow down the faulty part(s). I've seen posts regarding the first problem piece, C802 and it does look buldged from the sides. Aside from that, capacitor C907 looks like it might be buldged too from the top, but needs y'all input on it.
    I did a search for this specific model (50PM9700) but didn't get any hits on it. I believe the power board is a EAY62609701.
    The Y board is not connected directly to the power board. It's connected directly to the x board.
    I have a meter but I don't believe it's the right one to use. ANNNYYYY input is GREATLY appreciated!!
  • JDMugenBB1
    • Jan 2017
    • 20
    Re: LG Plasma 50PM9700 - same old double click & no start
    Here's a pic of the lay out.
    • JDMugenBB1
      • Jan 2017
      • 20
      well... didn't get anyone's input/feedback on the capacitor at C907, but I ordered a repair kit from shopjimmy which included the one at C802.
      http://www.ebay.com/itm/271871604304...%3AMEBIDX%3AIT
      Hopefully this is the only issue I have... but since the repair kit includes both fuses... I might replace those just for preventative maintenance.
      Wish me luck!
      Ceasar
      • JDMugenBB1
        • Jan 2017
        • 20
        Replaced capacitor at C802 and it works perfectly!! missed this TV so much!
        the process went fairly easy... but I did have a little issue with my soldering iron and its heat points on the tip. I had to move it around to find the hottest spot... HOWEVER, while doing that... I kinda burned a section of the board where it says "C802" on the backside of the board. I've attached a pic.
        The TV still works... but was wondering if the damage I created will be an issue on the future.
        Any feed back would be appreciated!
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Good job
          • JDMugenBB1
            • Jan 2017
            • 20
            Originally posted by ReeceyBurger123
            Good job
            Thanks! It would because of this Forum I was able to fix it!
            Think I'll have any issues with the section of the board strip I burned?
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              It shouldn't cause any problems since there are no copper tracks around it.
              • JDMugenBB1
                • Jan 2017
                • 20
                does anyone have a REALLY up close picture of the issue they are having where the Ribbon gets cut by the plastic piece along the edge?
                • jjanssen7
                  • Nov 2012
                  • 252
                  See this thread especially post #10
                  https://www.badcaps.net/forum/showth...light=50pa6500
                  • JDMugenBB1
                    • Jan 2017
                    • 20
                    So my TV has the "magic" pointer with the remote control, where the arrow pointer appears on the screen.. much like a computer mouse.
                    using it aint so bad... unless you have to Type in something into the URL or the Web browser on the TV... or if you are typing in a search for a movie title.
                    My question is, can you connect a Bluetooth wireless Keyboard to use, instead of clicking on eeevvvery single letter?
                    The side of the TV has USB IN ports.
                    • rimwall
                      Sony KD-65x7500D - double image - Tcon or Panel?
                      by rimwall
                      This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
                      I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
                      11-18-2025, 02:09 AM
                    • netgearnetgear
                      TOSHIBA 32C100U1 - Faulty display (double images and lines)
                      by netgearnetgear
                      Good day all,
                      I have a Toshiba TV, model 32C100U1 that turns on, displays fine for 5 min, sometimes 10 min and even 25 min then it starts to show double image, wrong colours together with lines as seen in the attached. I have measured and documented the tcon voltages both when the Television works fine and when the problems described occurs. It is important to note that the voltages are the same on the tcon board. The LVDS cable, tge panel ribbon all test good. I resoldred all the main ic's connections pins, connectors and even reflowed gamma chip. I tried to block some of the...
                      10-27-2025, 08:07 PM
                    • alltvrepairs
                      Hisense 55AS6G screen double sided tape required
                      by alltvrepairs
                      I need to replace the LEDs of this TV. The screen is glued with double sided tape. This video shows the proceudre required.
                      I need a source for this type of double sided tape adhesive please.
                      https://www.youtube.com/watch?v=bN6g...nel=QUADRA-NET
                      Tks!
                      07-17-2025, 09:32 AM
                    • howardc64
                      TCL 49S405 double image
                      by howardc64
                      LCD displays a 2nd image slighty offset vertically. And multiple pairs of black lines along the bottom. Probably common as google "TCL 49S405 double image" pulls up this ifixit post ( link ) with identical ( nearly, but their fault seems to be on the other half of the panel than mine ) problem without solution.
                      This one looks to be a more difficult to diagnose because most? of TCON seems integrated ( CSOT BGA on buffer baord) into the left panel edge board ( looking from rear of TV) There are 2 buffer boards for each 1/2 of the screen. Main connects to the left buffer board...
                      06-23-2025, 03:20 PM
                    • piershs
                      Toshiba plasma 50WP16 wierd double image fault
                      by piershs
                      My 2001 Toshiba 50WP16 50" plasma TV has, after 20 years of trouble-free service, developed a wierd fault in the last 14 days during normal viewing - with no loud bang or smoke or any other excitement.
                      Every 15-30 secs the right hand half of the image has a "glitch" for about 1 second before reverting to normal. The glitch has two forms and also depends on the aspect ratio setting (see photos):
                      • 16:9 either a) a visible seam between LHS and RHS of impage or b) LHS image duplicated on RHS (photos 16x9)
                      • 4x3 either a) no image on RHS or b) RHS image offset by 1/6th
                      08-01-2020, 01:07 PM
