Insignia NS-P502Q-10A Suspected bad Y-Main Board
  • thewilly
    • Jan 2017
    • 10
    This is the first I've messed with a TV. I have experience with analog guitar amplifiers and general household electrical.
    My 50" Insignia plasma turned off while I was watching it. When I tried to turn it back on it would click and try to turn on then shut itself off. I did some reading then opened up the back and started troubleshooting. I believe it is the Y-Main board, there is also a separate Y-Buffer on this model.
    I looked over the tops of the boards and did not see any apparent damage or burns and checked all removable resistors for continuity and they passed.
    I disconnected the cable to the Y-Main board and powered it up, the TV turned on and stayed on.
    I reconnected the Y-Main and disconnected the Y-Buffer. The TV turns on then shuts itself off.
    I inspected the Y-Buffer when it was out and didn't see any indications of burnt components. I did not fully remove the Y-Main but do not see an issue from the top of the board, there's no bulging caps.
    I think I've got it isolated to the Y-Main.
    Should I replace both the Y-Main and Y-Buffer or would I be safe to just replace the Y-Main for now to see if that fixes it? Or if it turns out to be the Y-Buffer would I risk frying my new Y-Main if I don't replace both at once?
    Thanks for the help!
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Insignia NS-P502Q-10A Suspected bad Y-Main Board
    Seems like the Ymain but I aint helping further till you help us. Thanks.
    • thewilly
      • Jan 2017
      • 10
      sure, happy to help. whatcha lookin for?
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Pictures and meter readings please, use the search feature and google to help you along the way. Test the Psu Vs and Va voltage with and with out Y connected and Ysus voltages.
        • thewilly
          • Jan 2017
          • 10
          Here are readings with the Y-main disconnected:
          With the Y-main disconnected the TV stays turned on
          PSU Vs: 209
          PSU Va: 56
          These are both per the spec label.
          Here are the readings with the Y-main connected
          With the Y-main connected the TV turns itself off then attempts to turn on again a few seconds later then shuts off again and continues in this loop.
          PSU Vs: 0.8
          PSU Va: peaks at 22
          Y-main VScan test point: peaks at 0.4
          I didn't notice other test points on the Y-Main board
          I have not tested pins to the Y-buffers
          I have checked all fuses for continuity and they pass
          Here is a link to view high res photos: https://postimg.org/gallery/1ca5xxp08/
          Full TV Back:
          Spec Label:
          PSU Board:
          Y-Main & Y-Buffer:
          Thank you for the help! Please let me know if I need to pull more readings and what the next step is.
          • thewilly
            • Jan 2017
            • 10
            PSU Vs: 209
            PSU Va: 56
            In case that wasn't clear, the voltages read exactly as expected, I didn't just post the label voltages
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Ok what does Vsc do please ? Also these sets are known for a bad Ymain and buffer, same as a Samsung B550.
              • thewilly
                • Jan 2017
                • 10
                I didn't see a test point for "Vsc", I did see one labeled VSCAN on the Y-main board. It's not visible in the photos, its jammed in there next to a large transistor and my photo angle doesn't catch it.
                I guess the Vsc test point is labeled VSCAN and located on the Y-Main?
                I tested the VSCAN point with the Y-main power cable connected, which means that the TV would power on then auto shut-off. The voltage peaked at about 0.4V before the TV shut off.
                I just went and tested the VSCAN point with the Y-main board disconnected and it read -130. I didn't test it before because with the cable disconnected I wasn't expecting it would read anything
                I checked the Ve too. With the Y-main disconnected (TV stays on) it reads 87. With the Y-main connected (TV powers on then shuts off) it peaks at 0.4.
                Thanks for all the help!
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  So Vscan on the Ymain with the buffer out stays at -130 ?
                  • thewilly
                    • Jan 2017
                    • 10
                    Vscan with the main power cable running to Y-main disconnected but the buffer board connected reads at -103 (130 was a typo)
                    I have not tested it with the buffer board pulled out
                    there is another small power cable at the bottom of the y-main that connects to a logic board, i've left that connected for every test.
                    • thewilly
                      • Jan 2017
                      • 10
                      With the buffer board pulled out the VSCAN measures around 0, whether or not the power cable from the PSU is connected. There is another power cable between the Y-Main and a logic board that seems to supply some current.
                      With the buffer board installed and the power cable from the PSU disconnected the VSCAN reads -103. With the PSU power connected the TV automatically shuts itself off, the voltage on VSCAN climbs to less than 1 volt before it turns off
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        Ysus is faulty then.
                        • thewilly
                          • Jan 2017
                          • 10
                          Thank you! Would you recommend replacing but the Y-Main and the Y-Buffer at once or would I be safe with just the Y-Main?
                          • steves7839
                            • Nov 2014
                            • 200
                            Coppell TV blog has weighed in on this question re a similar Samsung plasma Panel, S42AX-YD01. Search their blog for LJ92-01200A. PlainBill has also weighed in on this forum with an opinion to replace both. Search for the thread "Philips 42PF7320A/37 42" Plasma Repair"
                            • thewilly
                              • Jan 2017
                              • 10
                              Thanks! Those were very informative. I'd suspected that replacing both would be the best/safest option.
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                • uk
                                http://blog.coppelltvrepair.com/2010...according.html
                                • cajoeg
                                  Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
                                  by cajoeg
                                  Hello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
                                  The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV...
                                  02-10-2025, 04:01 PM
                                • jadao
                                  Acer Predator Helios Neo 16 BIOS corruption suspected
                                  by jadao
                                  Status: Power on with fan but no post dead brain no usb activity, bios corruption suspected
                                  S/N: NHQMAAA0033150C8367600
                                  SNID: 31505125476
                                  MB: DAZGRMB2AC0 REV C
                                  Can you please fix it?
                                  Thank you!​...
                                  09-12-2024, 09:24 PM
                                • freakorio
                                  Need Help To Identify Component on Ymain LJ41-05120A
                                  by freakorio
                                  Hi guys , i hope this is the right place , i got Plasma Samsung PS-50Q91H and i need to repair Ymain LJ41-05120A , but those component are burn and i can not identify to replace those part , and the part are blue capacitor and the location are C5105 and C5106 and here i attach the part that need to identify , and one more thing , i also need to replace Zener Diode on location ZD5502 and the part are BZV55C because mine is short but i don't know the voltage because those parts are release with many type of voltage. Looking forward for your kindly reply
                                  05-21-2024, 02:32 AM
                                • valvashon
                                  Insignia NS-LCD19-09 (third and final post, hopefully!)
                                  by valvashon
                                  I have been going round and round with this one for a couple of years. It's a 16x10 display that allows you to size your OTA picture correctly to 16x9 and that makes it kind of cool so I really want to keep it on my OTA monitoring wall. Accidentially let a screw roll under the powered power supply board and ended up replacing the MOSFET drivers for the inverters, then one of the Schottky rectifiers for one of the supplies, then the PS caps becuase I fired the parts cannon at it one day.
                                  Problem was no cold startup; it would only startup when you applied a heat gun to the board....
                                  10-22-2025, 12:33 PM
                                • valvashon
                                  Insignia NS-LCD19-09 no standby LED; (new problem)
                                  by valvashon
                                  Having a new problem with the 19" Insignia that I modified with one of my automatic turn on circuits. That is now completely disconnected so that is not the issue. I was doing some modifications on that circuitry and managed to short something out on the underside of the power board.
                                  Actually found and bought the service manual (who knew it was even available?!) which brought me to the High Voltage Startup Circuit controller chip.
                                  Looking up that chip number- LD7575APS brought me to the attached datasheet. I have marked my voltage readings on the schematic sheet (open in new...
                                  08-30-2023, 10:41 AM
