Rebuilding TNPA5330 , TNPA5349 & TNPA53305
  • syaoran123
    • Jun 2014
    • 178
    Re: Rebuilding TNPA5330 , TNPA5349 & TNPA53305
    @_@
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Originally posted by syaoran123
      The FGD4536TM that everyone is talking about doesn't seem to work for me. I fitted them to a tnpa5335 board and blew up immediately. I know these are original because I ordered them from RS which is a certified retailer. They came in very small TO-252 packages.
      As soon as I replaced them with RJH3047, the TV fired up straight away.
      So what is the success rate of the FGD4536TM?
      Ive used them a few times not an issue, maybe you got fakes ?
      • syaoran123
        • Jun 2014
        • 178
        Like i said, I ordered from RS. Look that up.
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Hmm odd, I used them to sub30f131.
          • syaoran123
            • Jun 2014
            • 178
            Are they normally small? Heres what the packaging looks like and a size comparison.
            • Moreno83
              • Jun 2014
              • 2008
              • The Netherlands
              #26
              FGD4536TM is working perfectly even from RS. Batch from rs ends with AA i think.
              Maybe you got a bad one? Voltages going to ysus are ok? 215v?
              • Moreno83
                • Jun 2014
                • 2008
                • The Netherlands
                #27
                Yes they are small. Did not have a problem with these tbh.
                • syaoran123
                  • Jun 2014
                  • 178
                  Its working when i substituted them with another part :/
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    #29
                    Maybe you subbed them in the wrong area ?
                    • syaoran123
                      • Jun 2014
                      • 178
                      Not to mention... I had made another attempt previously with another board. Both times failed
                      • syaoran123
                        • Jun 2014
                        • 178
                        Take a look at my job. It may look ugly, but it works good as new.
                        • Moreno83
                          • Jun 2014
                          • 2008
                          • The Netherlands
                          #32
                          I dont know why your fets blow up but i dont have any problems with the fgd4536tm. All my repairs work with these fets.
                          • syaoran123
                            • Jun 2014
                            • 178
                            Very peculiar. And the fgd's are so much smaller and easier to work with. I'm just not having any luck.
                            • Moreno83
                              • Jun 2014
                              • 2008
                              • The Netherlands
                              #34
                              Hmmz back to the drawingboard. The last board with the missing pad turns on but the picture is not good. TPVsus is 215v so thats good.
                              Board does the same in a different tv. Its a problem somewhere in the recovery section and i think it happened after rjp63g4 exploded taking out IC921.
                              Service manual does not list all the components so my best bet is replacing the whole left side around ic921.
                              Anyone any suggestions? The screen slowly comes to live...
                              • ReeceyBurger123
                                Never Give Up !
                                • May 2014
                                • 7325
                                • Britain
                                #35
                                Crist almighty what a job, but if it works fair enough.
                                • Oleg78
                                  • May 2019
                                  • Russia
                                  #36
                                  Good day! I have some problem with my tnpa5349 , after change four shorted 30f131 (i install rjp3047 without d-pak diodes, i forgot name those near 30f131) and rjp63g4 (i install rjp62k2 )- it worked perfectly on previus repaired tnpa board , sn board worked, but image is not good -very high brichtness on medium settings of brightness and contrast and many different color points all of screen. I was cheking all tiny transististors and diodes near with fets and igbt, all is ok. Need yor help thank you
                                  • Mark D
                                    Samsung UN65JU67ODFXZA Version TD01 Schematic and Parts List
                                    by Mark D
                                    The TV is a Samsung UN65JU67ODFXZA Version TD01. I replaced the power source board and the TV is now working, but I decided to try and troubleshoot the old board to fix at the component level. Trying to get a schematic and a parts list has proven to be an issue. Trying on my own, I can't tell you how many times my Norton security has flagged sites as "malicious". I ordered a service manual from ServiceManuals.net, paid $16.99 and got 66 pages of everything BUT schematics and component parts list! Can anyone steer me in the right direction? Some of the surface mounted component parts...
                                    10-29-2024, 03:15 PM
                                  • tvtimmy
                                    More fake parts
                                    by tvtimmy
                                    I ordered 50 FGD4536 ibgt's from them and recieved 50 fucking blanks, useless Chinese forgeries for $44. I can get a full refund if I spend at least $15 to ship the garbage back to China for some other person to buy. I decided I would like to publicly disgrace them and just eat the $44. They advertised them as used but working. They came in a strip of new FAKES that looked nothing like the real ones. BEWARE OF THOSE SHADY BASTARDS!
                                    12-22-2021, 02:04 AM
                                  • 2elw
                                    SVOD4 PCB pictures + parts
                                    by 2elw
                                    Hey, I find it very absurd that the SVOD4 costs so much and has zero documentation. I had no other choice than to buy it to unlock ECs, if there was any documentation or firmware avalible I could've made it or something simmilar. Anyways here are some of the most important parts:
                                    STM32H723VGT6 MCU - It's a microcontroller by STMicroelectronics and its the whole brain of the SVOD4. It has flash memory for the firmware which can be updated by the SVOD4 program. Its also powered by the AMS117 which converts 5v into 3.3V. 7€ on AliExpress.
                                    GW1N-UV9UG169C6/I5 FPGA - Its a...
                                    07-04-2025, 12:23 PM
                                  • SurrealMustard
                                    What parts can be salvaged from a plasma with a damaged display panel?
                                    by SurrealMustard
                                    I recently found myself the proud owner of a later-model Samsung plasma (the PN59D7000 for those keeping score at home) whose panel was, unfortunately, damaged in transport. I'm now preparing to part it out, but am curious as to whether or not any damage would have come to any of the components by attempting to power it up with the panel being broken. I read in one Avsforum thread (for whatever that's worth 😂) that the "scan driver boards" (by which I assume he means buffer boards) could be impacted by doing so. Is that actually the case? If so, since I don't intend on selling bad...
                                    03-09-2025, 08:29 PM
                                  • DynaxSC
                                    Asus Rog Strix B360-I Gaming - Parts Identification
                                    by DynaxSC
                                    I have an Asus Rog Strix B360-I Gaming with missing parts. I know there is a resistor missing for sure, but nearby it seems there might have been also a transistor or mosfet. Below the picture of the area on the board with the missing parts. The interesting area is inside the rectangle.
                                    I'd appeciate if somebody could make a detailled picture of this area from a working board and post it here. Getting the parts values would also be helpful. The revision of the board is 1.02 .
                                    Thanks in advance...
                                    08-23-2023, 07:56 AM
