A friend has given me this old set to have a look at. It is old, but owner would like it fixed if poss, so I said I'd give it a try.
It has the 17PW15-8 power supply and the main board is a 17MB15E-7. It doesn't look like anyone has had the back off before.
It appears to be stuck in standby, the blue standby LED stays lit.
First thing I did was replace the two cap's 877 & 878 but still the same. Can't see any bulging electrolytics, it doesn't look like the set has had much use in fact, it's all very clean.
I checked the voltage on the 24V rail to the inverter and it does increase somewhat when trying to start up the set but it trips and returns to 0V after about 1s. Same with the 5V rail. C819 sits at 325V in standby, rises to about 390V when attempting to start then returns to 325V.
As the set's not worth much I thought I'd ask if anyone has had the same fault, or could suggest things to check rather than waste much time on a possibly fruitless mission.
Any help greatly appreciated.
TIA.
TIA.
