Sanyo (Vestel) CE26HW03 with 17PW15-8
  • Agent24
    I see dead caps
    • Oct 2007
    • 5095
    • New Zealand
    Re: Sanyo (Vestel) CE26HW03 with 17PW15-8
    If there's no power to Pin 6 of PL803 on the good PSU, I must be misunderstanding the circuit operation. Unless it's supposed to be fed with 3.3v from the mainboard? I don't know.
    If you get 24v and other things from the good PSU then the main supply from IC807 must be running on the good board. But I would have thought that this would not start until the mainboard tells it to.
    What voltage do you get across C819 on the good board? Without main etc connected.
    It's good you get the 3.3v and 5v standby rails from PL806. It shows that the IC806 standby circuit is working somewhat.
    -David VanHorn
    • Jaime Morillo
      Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
      by Jaime Morillo
      Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
      The TV was stuck on the logo and I couldn't access the update menu.
      I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
      The image result was good, but the image is inverted.
      The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
      Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
      08-18-2025, 11:38 AM
    • France_53
      Vestel tv, how to flip the image?
      by France_53
      Hello everyone from Italy, I'm here to ask for help on a Vestel TV, I've had a Vestel TV branded "XD" with a broken screen for years, but now I've found a Telefunken (still Vestel but older) and I've mounted the panel on the "XD" TV, it works, but the screen is upside down, given that Vestel does not allow you to rotate the image from the service menu, does anyone know how to solve the problem? the original panel is marked ves315WNDS-2D-N12 while the main board 17mb110, the panel I mounted instead in the tv (from the telefunken) is a ves315WNDA-02. ... It is not worth repairing...
      05-12-2024, 05:22 AM
    • FlailingEngineer
      Help with Bush Tv (Vestel 17mb95m Mainboard)
      by FlailingEngineer
      Hi, I was recently given a Bush Smart TV by a friend and the main board seems to be hanging on by a thread.
      Before we get to that, my first obstacle was figuring out the model number since the back sticker has gone for a walk. Upon taking off the back case, I noticed the following Vestel parts, 17MB95m mainboard, 17IPS71 (what I'd assume is power supply) and a VES420UNVL-3D-S02 display panel. After doing some research I think the TV I have is a Bush ELED42240FHDCNTD3D, based on the matching image here (https://www.manualslib.com/manual/11...td3d.html#manu...
      05-31-2023, 06:52 AM
    • lberkani
      Request: USB firmware for Toshiba 65UL2163DG (Vestel 17MB180E) - panel VES650QNTX-N2-N42
      by lberkani
      I’m looking for the correct firmware for my Toshiba 65UL2163DG TV.
      The mainboard is Vestel 17MB180E, and my panel is VES650QNTX-N2-N42.
      The board I received is flashed for VES650QNDB_N41 and shows double “No signal”.
      I need the correct USB update package (upgrade_mb180.zip / upgrade.bin) for:
      - Toshiba 65UL2163DG
      - Vestel 17MB180E mainboard
      - Panel VES650QNTX-N2-N42
      - Version V1.28.100.0 if available
      If anyone has the file, please share a download link (WeTransfer, MEGA, Google Drive) and include version.txt...
      11-11-2025, 12:37 PM
    • hazi12
      Vestel main board 17MB140TC
      by hazi12
      Hello, board 17MB140TC, I need to change the remote control in Vestel tool box 1.1. The original is there
      Rc48xx_2D and I want to install TOSHIBA-Rc481xx, but the program says that a maximum of 9 characters can be entered. I only entered Rc481xx and the program does not accept the driver I have in the original. Does anyone know how to do this? Other Vestel codes work.
      I can send a dump....
      10-01-2025, 01:28 PM
