Vizio E551VL Relay clicking on and off
  • RRice25541
    • Nov 2015
    • 47
    I've pulled the PS from the set and checked all caps with my digital ESR low ohms meter(Dick Smith unit) all caps are good, tested all transistors and FET's again all good.
    If i jump the 5v pin to the PS_ON the 12v,24v and 18v power pins come up briefly and then rapidly drop down to 0v(like the PS was unplugged and the caps are draining off.
    I'm wondering if the SG6742MR chip is the bad part in this PS.
    anyone have any idea's on this a schematic would help greatly if anyone has it.
    the PS is DPS-321AP
  • beetle1303
    Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
    by beetle1303
    I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
    On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
    01-13-2025, 08:49 PM
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
  • DodgyTech
    60" LG 60PB690V relay clicking issue
    by DodgyTech
    I require some help with my TV. The TV standby light blicks on and off with a clicking sound (relay?) from the back. After I opened up the TV, I set about troubleshooting by unplugging the boards to try and isolate the problem. My troubleshooting suggests that the logic board is causing the issue, but it could entirely be the YSUS board which is only activated once the logic board is connected.
    I have recorded a video which I thought would be an easier way to explain the problem and show the boards at the same time.
    I would like to try and identify...
    07-07-2023, 10:30 AM
  • GraphicMan
    Pioneer amplifier A-205 Relay not clicking after a mistake i made
    by GraphicMan
    Hello guys
    Because the unit is old (but only occasionally used) the loudness button causes some noise due to bad contact,
    sprays did not work, so i decided to solder the pins that it connects on the pcb at the on (loudness on) position
    i did that and it worked fine, i know from the bottom of my heart that the switch connects 2 pins and also d/c other 2 pins
    on every position it have (6 pin switch), so i was curious what would happen if i clicked the switch off while the pins are soldered at on (so basiclly on and off at the same time), when i did so the sound is gone, nothing...
    05-05-2024, 06:20 AM
  • nbnb
    Vizio VO47L FDHTV30A Picture but no speaker audio, clicking sound
    by nbnb
    I have a Vizio VO47L FDHTV30A. The picture works well, but the sound only works through the RCA output jacks. The sound does not work through the internal speakers or the headphone jack. The TV has a rapid clicking sound when the tv is on that occurs about 4 times per second. The clicking sound volume is fairly low and is not affected by adjusting the internal speaker volume level. The clicking occurs whether or not I disable the internal speaker through the Vizio setup menu. The clicking only occurs while the TV is on.
    Any idea what is causing the clicking sound? Any easy way to...
    11-23-2019, 12:03 PM
