42"Fluid plasma tv Mod#(Samsung)pn50b550t2f
  • rich-t
    • Dec 2016
    • 70
    Re: 42"Fluid plasma tv Mod#(Samsung)pn50b550t2f
    i wasnt on about the circle more the tuner looks soldered to that board is that the board you have now ordered to swop?
    No, It's the logic board mounted underneath th 1 shown.
    • vinceroger69
      • Mar 2012
      • 6714
      #62
      the board you was jumping the pins on? just trying to make sure you have ordered the right board you need
      • rich-t
        • Dec 2016
        • 70
        There is a pic. in post 14? or 15. Where I jumped 3 and 4
        • vinceroger69
          • Mar 2012
          • 6714
          #64
          well if you have ordered that board it maybe the wrong one but let someone else confirm, we was using the jumpers on that board to see which board was faulty which it points too the main board the one with the hdmi/tuner on hence peoples comments regarding the tuner but hey i could be totally wrong let someone else confirm which board you need to replace.
          • rich-t
            • Dec 2016
            • 70
            Reecey said to order the main (logic) board.
            link [TM].pdf&mfg=Philips-Magnavox
            • rich-t
              • Dec 2016
              • 70
              Go to pages 5 and 6. Item 2
              • vinceroger69
                • Mar 2012
                • 6714
                #67
                post 12 reece mentions mainboard? i class the logic board/tcon,the mainboard i class is the one with inputs ie tuner/hdmi scarts etc im only trying too make sure its the correct board saves you wasting time reece may see this thread soon and assure us which board needs to be replaced it maybe me wrong so dont order one just yet.
                • rich-t
                  • Dec 2016
                  • 70
                  Did you get that link to work? THe board listed as no. 2 they call the main board. Why are electronic nomenclature so confusing? in mechanics we don't call a piston a wheel. lol.
                  Oops , already ordered. :-(
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    #69
                    im a ex mechanic but hey thats getting more into electronics to with ecus/can bus etc etc so loads more to fault find lol , as i say i may be wrong hence why saying wait for conformation as to which board im more used to fixing lcd/not plasmas i was more concerened you waited ages if you had ordered the wrong board and you could of found the correct one in that time.
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      #70
                      Mainboard-hdmi inputs etc.
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        #71
                        just to make sure reece now hes ran the tests and the test patterns show up ok etc its the mainboard with hdmi/tuner thats at fault and will need to make sure board is for his country regarding the tuner etc thanks reece im still learning too.
                        • rich-t
                          • Dec 2016
                          • 70
                          I guess I'll have to check on another manual because looking at the 1 shown don't seem to have a tuner??? and the parts description calls it a LOGIC-main board.
                          • vinceroger69
                            • Mar 2012
                            • 6714
                            #73
                            the picture you circled that wrong lead in blue thats the board you need with the hdmi ports on (post 36) whats the part number from that board? we need the part number from the board in your tv so we know its the right one
                            • rich-t
                              • Dec 2016
                              • 70
                              Well, can't find a board so I guess I'll have to find someone who know how to test and repair it, or scrap it, :-(
                              • rich-t
                                • Dec 2016
                                • 70
                                Reeceyburger123, Would you perhaps know where Ican find out how to test and repair this main board? I can't find one anywhere.
                                • ReeceyBurger123
                                  Never Give Up !
                                  • May 2014
                                  • 7325
                                  • Britain
                                  #76
                                  Find the schematic for it bud and get testing the regulators etc and fuses on the board. If not what is the model of the pcb ?
                                  • rich-t
                                    • Dec 2016
                                    • 70
                                    Hi, Reecey, I've tried to find this board on any site I could find that has samsung manuals etc. but no joy, this is a real odd ball. It has 50+ caps, various chips and ic's etc. but no fuses and no recognizable no's on the board that makes sense (3 small paper tags). I'm attaching some pic's of the top of the board and 1 of the bottom which has a bar code and a no. I;m also sending pic of the logic that is screwed on top of it that has the regular type no.s.
                                    Hope you can help. Tessting of all these components if way above my pay grade. :-)
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      #78
                                      pic 1 above the black heat sink whats that long number?
                                      • rich-t
                                        • Dec 2016
                                        • 70
                                        That no. is 200-100-iv501b-ch rev c.
                                        • rich-t
                                          • Dec 2016
                                          • 70
                                          on the top right main logic board it has the following no's
                                          model no. 42 hd wd w3 lm
                                          pcb no. LJ41-05078
                                          REV. R1.729 (08 03 26
                                          NO'S ON MAIN BOARD- TAG ON CABLE TUNER
                                          TD 1636EF / FGMP-2
                                          3139 147 269819
                                          0818 SV20 000000
                                          SMALL GREEN TAG 29C69C5C
                                          O81015
                                          SMALL BLUE TAG P0151-
                                          ge421axa2h
                                          bottom small green tag
                                          141668
                                          Tag under bar code bottom of main(tuner board)
                                          ptd5u1108b00104
                                          45 899 ksige21axa2h rev.01
                                            Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                            by sam_sam_sam
                                            This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                            I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                            I am comparing them to a brand new one that I installed
                                            The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                            I going to let it run for several days before I remount back on the wall next to the...
                                            09-05-2024, 06:48 PM
                                            HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i7-9700 Specification for Upgrade or Repair
                                            This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                            09-12-2024, 02:30 PM
                                            HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i5-9500 Specification for Upgrade or Repair
                                            HP ProBook 430 G7 + APC Back-UPS 700VA Notebook 400 Specification for Upgrade or Repair
                                            This specification for the HP ProBook 430 G7 + APC Back-UPS 700VA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G7 + APC Back-UPS 700VA boardview and 430 G7 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            09-06-2024, 08:10 PM
                                            HP ProBook 450 G7 + APC Back-UPS 700VA Notebook 400 Specification for Upgrade or Repair
                                            This specification for the HP ProBook 450 G7 + APC Back-UPS 700VA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G7 + APC Back-UPS 700VA boardview and 450 G7 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
