blaupunkt 40/148I stuck in stby
  • snowfun
    • Aug 2012
    • 21
    • Portugal
    Hey guys, i have a blaupunkt 40/148i -gb-5b-fhbkup-eu stuck in stby and the fault is bios dump corrupted.
    Please anyone have bios dump file for this model ?
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: blaupunkt 40/148I stuck in stby
    Had a look cant find a thing sorry, maybe use a spi reader and freeze the flash Ic sometimes allows you to read the data off it.
    • snowfun
      • Aug 2012
      • 21
      • Portugal
      Thanks for your work, but i can read the chip with my spi programer and the data is there. what address lines is corrupetd ? what can i do?.
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        Since you have St-By power...when you press the POWER button on the TV are you getting the PS-ON signal from the Main Bd to the Pwr Bd??
        • snowfun
          • Aug 2012
          • 21
          • Portugal
          No ps-on signal not present,But I'm sure there a problem with the firmware because i programed with another firmware (40/148k ) and works only don't save anything and sometime frontal led blinks, i enter in service mode and could verify 2 errors, the MB not is MDS309 BP85.
          So the problem is wrong bios firmware
          Any help ???
          • Daniel Larsson
            Help me verify my NAND dump (attached) from LG SK10Y soundbar stuck in PLEASE WAIT - is it missing critical data?
            by Daniel Larsson
            I’m trying to bring a LG SK10Y soundbar back to life. Currently it is stuck in the “PLEASE WAIT” loop.
            My conclusion so far is that something fails to boot fully, but it does start via eARC and can play perfectly good sound until watchdog shuts it down.
            After dumping NAND with a T48 programmer, extracting with binwalk and exploring with Ghidra I think:
            • Kernel B is present, but no Kernel A. Is that normal?
            • SquashFS A/B are present
            • Bootloader is present
            • UBI region is completely empty (only volume 0 / layout volume exists)
            • No system.cfg,
            11-13-2025, 03:19 PM
          • alext28
            Precision 7670 Corrupted bios dump
            by alext28
            hello everyone ,
            i have a Precision 7670 with corrupted bios dump 3 amber 6 light (Flash corruption detected by SBIOS) I need a clean bios dump or repair my bios dump
            thanks for your help !​...
            01-30-2024, 10:57 AM
          • James194zt
            Acer Nitro 50-640E Corrupted BIOS Dump
            by James194zt
            My daughter has accidentally managed to kill her Acer gaming desktop it has a blank screen after updating and when you press the power button the fans spin, light comes on and it makes 1 long and 1 short beep and no attempt to boot.
            All basic troubleshooting has been done we replaced CPU, GPU and RAM from a working machine and no joy, I also noticed a post on here with the same issue and it was the BIOS. I am pretty sure also because it was doing a BIOS update that stopped it working, she knocked the keyboard out by accident during the update and the screen just went...
            04-28-2025, 03:29 PM
          • magneh
            Sango J1900 - POS - corrupted bios but unable to find dump
            by magneh
            Hi all!
            long shot but lets see
            POS device, with a what I suspect a corrupted bios.
            All power rails are up and running, but not POST.
            On Sango site cant find any bios file.
            Contacted them by mail and asked for it, but not sure they will even reply
            Model: Sango J1900
            Board: SANGO-MB-J1900
            SN:RC18110135
            Would someone be able to take a look at this backup dump and check if something can be done ?
            Thanks for any help
            Apreciate it
            Cheers...
            03-01-2024, 09:56 AM
          • Stunt
            Hp Laptop Stuck on Hp protected by hp sure start screen
            by Stunt
            Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
            I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
            I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
            Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
            screen that's it and stuck there. I left it until the following day and i still...
            09-02-2025, 01:51 PM
