Samsung PN50B650S1F sound but no picture
  • WHaThEFLuX
    • Feb 2015
    • 277
    Re: Samsung PN50B650S1F sound but no picture
    bump
    "You can only learn so much doing simple recapping and fixes. Ideally you want a really hard one to fix where you end up with a lot of dead ends and frustration. Then, and only then, do you learn how things really work."
    -retiredcaps
    • WHaThEFLuX
      • Feb 2015
      • 277
      Anyone get a chance to look at those videos?
      -retiredcaps
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Look exactly like sustain voltage loss, has the Ymain arrived ?
        • WHaThEFLuX
          • Feb 2015
          • 277
          Should be here tomorrow, the postal service has been a mess since it's so close to the holidays.
          As much as I'll be relieved if the "new" Ysus repairs the set, I'd really love to know what's wrong with the original, I might have to cross check all the components to see if I can find anything, my curiosity always gets the best of me!
          -retiredcaps
          • WHaThEFLuX
            • Feb 2015
            • 277
            Well now I know why I couldn't find anything wrong with the original Ysus, there's nothing wrong with it! The supposedly "good" board I got in the mail today did the exact same thing as the original, which means I've received a faulty board which I highly doubt, or I've set my sights on the wrong problem.
            Not sure where to go from here but I'm assuming it means throwing an Xsus at it and then most likely a Y buffer?
            -retiredcaps
            • WHaThEFLuX
              • Feb 2015
              • 277
              Question, if the Xsus IS the problem would removing it and testing the Ysus give me steady voltage at VSCAN?
              EDIT: Guess not, with the Xsus removed I'm still getting erratic voltage at VSCAN, only about 100V less.
              -retiredcaps
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                #27
                What about with the buffer out does Vsc go higher than 100v ?
                • WHaThEFLuX
                  • Feb 2015
                  • 277
                  I'll test that now, you want the X out and the buffer out or just the buffer?
                  -retiredcaps
                  • WHaThEFLuX
                    • Feb 2015
                    • 277
                    OK finally! With the "new" Ysus board in the set and everything else connected except for the buffer, VSCAN is at a steady 200V!
                    I just realized that after replacing the ICs on the original board I never checked it with the buffer removed!
                    So now I'll put the original back in with the buffer removed, if it all checks out I'll return the Ysus I just received and get a working buffer, if not I'll just order the damn buffer and be done with it.
                    I guess with everything getting hectic for the holidays my diagnostic skills took a back seat!
                    -retiredcaps
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      #30
                      Lol it happens, I thought you said you checked it or I read it wrong which is probably the case. Hopefully you can sort it. Though good to keep a Ysus on hand and Ive had these blow up as I said and they are a pain. Also if a buffer does sort it I suggest you add heatsinks with thermal silicon to the chips on the replacement buffer.
                      • WHaThEFLuX
                        • Feb 2015
                        • 277
                        I believe after I replaced the chip I just connected everything back up to test and hoped for the best.
                        I will definitely do that, how does one go about adding the heatsinks? Pull them from another board? If you could go into a little more detail about the procedure that'd be great!
                        -retiredcaps
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          #32
                          Also order some small ram heatsinks and thermal plaster to put them on. You might need to trim the glue around the scan Ic. Also make sure to get ram heatsinks with no thermal tape on as that stuff is rubbish.
                          • WHaThEFLuX
                            • Feb 2015
                            • 277
                            Hope everyone is enjoying the holidays!
                            While I'm waiting for the buffer to arrive, another relative heard I was fixing this set and showed me his:
                            Is there any chance that this ISN'T the panel? Like tab bonds, loose ribbon, etc. Please someone tell me it's the panel so I don't have to have another 50" sitting in my house, I'm afraid if I keep acquiring sets my floor will collapse!
                            -retiredcaps
                            • ReeceyBurger123
                              Never Give Up !
                              • May 2014
                              • 7325
                              • Britain
                              #34
                              No, panel is dead. Single lines never fixable.
                              • WHaThEFLuX
                                • Feb 2015
                                • 277
                                So after receiving the Y buffer from across the pond, I installed it in the set along with the good tested Ysus and it fired right up!
                                In hindsight, if I would have just tested the original Ysus after repairing it without the buffer in, I would have realized that the IC Reecey mentioned was the only failed component on the board and reused it. Reecey, you were spot on!
                                I'd also like to mention that Tom was correct as well, if I would have tested OUTH(which I just realized was on the Y buffer), I would have discovered that the buffer was faulty.
                                Here's a pic of the boards installed with the heatsinks attached, hopefully they'll keep the buffer alive for a long time!
                                Big thanks to Reecey and Tom, you guys are top notch!
                                -retiredcaps
                                • ReeceyBurger123
                                  Never Give Up !
                                  • May 2014
                                  • 7325
                                  • Britain
                                  #36
                                  Awesome work, too bad I forgot to ask you to retest it with removed buffer. Ahh well you have a spare Ysus for when that one blows its self to pieces ehy and that bufer should only fail if the Ysus blows it with them heatsinks on lol good job
                                  • WHaThEFLuX
                                    • Feb 2015
                                    • 277
                                    Couldn't have done it without you man, thanks again!
                                    -retiredcaps
                                    • TR103
                                      by TR103
                                      - it keeps rebooting
                                      01-22-2025, 04:12 PM
                                    • Mgiffune
                                      by Mgiffune
                                      06-09-2024, 10:28 AM
                                    • Ierwin
                                      by Ierwin
                                      05-13-2025, 03:31 PM
                                    • jchang
                                      Samsung UN70NU6900F no picture and no sound
                                      by jchang
                                      Hi all
                                      I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                      Symptom:
                                      No picture no sound.
                                      When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                      No sound at all.
                                      What I tried:
                                      1. I tried unplugging the left or right ribbon...
                                      01-09-2023, 06:28 PM
                                    • Dodgethis
                                      Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                                      by Dodgethis
                                      Hello all,
                                      This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                                      09-11-2024, 07:39 AM
