Sony KDL-55EX723 4 blinks...
  • PowerAmpFreak
    • 979
    • Sweden
    I got a Sony KDL-55EX723 with 4 blinks.
    It starts up with proper picture for two seconds, then 4 blink code.
    0 no red standby light-check powercord or bad main logic board or power board, check standby volts
    1 red blink not used
    2 red flashes is bad power board, solution replace power board
    3 red flashes is bad main logic or power board, check for standby volts if ok replace main logic board
    4 red blinks- can be LD board or main logic board, check inverter board wires for arcing to ground
    5 red flashes- bad lcd panel connection or internal lcd short- squeeze bezel to locate bad connection
    6 red flashes- backlight issue, bad main board, or power board or inverter boards- check standby volts on power board. "backlight on" volts should be 3-5v from main logic board then 24v to inverter
    7 red flashes- main board over heating, can be short on power board or main logic board
    8 red flashes- main board sp prot, try power reset, update with usb, or replace main logic board
    9 blinks- check fan error, * if TV has fans
    10 blinks- digital board or tuner board * some Sony TVs may not have this board
    11 red flashes- bad main board, bad IC, replace main logic board
    12 red light flashes is tcon error bad T-con board or bad LCD panel, replace tcon board usually
    13 red flashing is backlight balance error bad lcd panel or inverter boards (common) or bal board on kdl-52v4100 only, replace inverter board usually then main logic board
    14 red flashes HFR- bad TCON or Bad LCD panel, replace tcon board. unplug tcon board if tv stays on without tcon board replace tcon board. "como sony tv reparación"
    No arcing can be seen, but I am not sure what to check on LD board ??
  • PowerAmpFreak
    • 979
    • Sweden
    Re: Sony KDL-55EX723 4 blinks...
    I changed the LD board from another working set, but that didn't cure the 4-blink code.
    I also changed the PSU and LED supply board from the same working set, no change.
    • dick_barton
      • Aug 2015
      • 6642
      • Wales
      It's an edge lit set. Are you confident that there is not an led problem?
      • PowerAmpFreak
        • 979
        • Sweden
        Of course not sure.
        So the problem is within the panel which makes it hardly worth fixing ?
        • jb_Bak
          by jb_Bak
          CN6401
          Pin 01 NC
          Pin 02 NC
          Pin 03 "BL_ON": 0V
          Pin 04 "N/C"
          Pin 05 "STBY 3.3V": 3.5V
          Pin 06 "GND": N/C
          Pin 07 "AC_OFF"...
          09-27-2021, 04:52 PM
        • Dani_2024
          by Dani_2024
          10-28-2024, 05:06 PM
        • ygorsan
          by ygorsan
          🧩 Problem Summary:
          • I
          Today, 08:34 AM
        • JDC
          (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
          by JDC
          ONN 100012588
          Issue: No Power, Then Rebooting After Main Board Change
          Short answer: replace main board and power board
          Technical answer: replace main board and Q306 & Q307 on power board.
          Long answer:
          TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
          07-15-2022, 07:39 AM
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
