Toshiba 40L1333DB - Standby light (LED) is blinking red & green with 0.5s interval
  • imranabbas
    • Nov 2022
    • saudia
    Re: Toshiba 40L1333DB - Standby light (LED) is blinking red & green with 0.5s interva
    Hi In my tv also I am facing this issue. When I on the TV only red & green lights blinking
    Toshiba tv model 50u5865ee
    Where i can get firmware for this model
    • vinceroger69
      • Mar 2012
      • 6714
      • uk
      Maybe ask in this thread include the mainboard number and also lcd screen details thanks
      https://www.badcaps.net/forum/showthread.php?t=59877
      • vader54
        • Sep 2023
        Same problem with my 48L143DG...
        • ThomasL
          • Aug 2024
          • Deutschland
          hey everybody - I have a 40L1343DG Toshiba - and I did as it was written in #9 - Menu starts again - nearly perfekt but i only can choose between antenna and kabel - my satellite option got lost - can somebody help me, how to get the satellite option back? thanks in advance.
          • nomoresonys
            • 12276
            • U.S.
            So looks like someone is blocking or not approving Diah's posts, well if you don't need his posts I guess you don't need mine either, I'm done till it's straightened out.
            • yokoono
              • Apr 2010
              • 505
              #26
              The motherboard is 17MB95 ???.
              1. Format a stick with fat32
              2. Put a folder called downloadprofile.mb95 on the stick
              3. You turn on the TV
              4. Insert the USB stick
              5. Type MENU 4725 and go to USB Operations
              6. Press OK on the remote control
              7. Wait 5 seconds and remove the stick
              8. Post the files here to see if the satellite function is activated.
              • ThomasL
                • Aug 2024
                • Deutschland
                #27
                hi Yokoono, thanks i did that - here the documents. If I understood the information in the Menu right - the "Satellite Support" is "No" - before I crashed and rebooted the TV it worked with satellite. thanks for you help in advance.
                  • 21606
                  Nope,someone is not blocking Diah's posts , i have tried to explain what`s happening https://www.badcaps.net/forum/genera...ls#post3322047 .Its the site`s Spam filter that`s the problem.
                  • nomoresonys
                    • 12276
                    • U.S.
                    #29
                    It is ridiculous, who REDESIGNS a site and just makes it worse in every way? That is what seems to have happened.
                    • yokoono
                      • Apr 2010
                      • 505
                      #30
                      If you haven't rewritten the software, try a factory reset first. MENU 4725, Diagnostic, Factory reset, OK.
                      • ThomasL
                        • Aug 2024
                        • Deutschland
                        #31
                        sorry that i wrote so unclear. i rewritted it, cause i didnt start at all. I did it like it was written in Post 9# with the 3 attached documents - with while plugging electric holding the "ok button" and at least it started again and showed the menu ( without satellite) - maybe i have the wrong data? sorry i m really not so good in TV or computing...
                        • yokoono
                          • Apr 2010
                          • 505
                          #32
                          Try:
                          2. Put a folder called profile on the stick
                          3. Unzip and put the 3 files in the folder.
                          4. You turn on the TV
                          5. Insert the USB stick
                          6. Type MENU 4725 and go to USB Operations
                          7. Press OK on the remote control
                          9. Wait 5 seconds and remove the stick
                          • nomoresonys
                            • 12276
                            • U.S.
                            #33
                            Well then, why isn't this happening to everyone???
                            • nomoresonys
                              • 12276
                              • U.S.
                              #34
                              Diah, if you read this, I put smdflea's response here, he surmises that 4 ? marks may have triggered the spam filter, I can say that I have seen less spam since the overhaul, was wondering if I would ever find anything good about it, lol:
                              • Diah
                                • Feb 2013
                                • 6438
                                thanks mate . what a silly filter.. this web design i saw at many others web. and there no such fault.. its look who admin it don't know how to configure the software.
                                • nomoresonys
                                  • 12276
                                  • U.S.
                                  #36
                                  Yeah, looks like they're playing favorites too, no matter tho, helping the owner isn't why I'm here.
                                  • ThomasL
                                    • Aug 2024
                                    • Deutschland
                                    #37
                                    yokoono thanks it works - unfortunatelly i had after some hours the same issues. i did what was written in #9 and than what you had written in #32 - and it will work again - i dont know how long it will work this time. but 1000 thanks - your helped me and my kids a lot i keep you updated -or if you have an idea to fix the problem permenantly - i would apreciat that :=)
                                    • naddaw000
                                      Toshiba 55U7863DG - green light blinking (17MB130S)
                                      by naddaw000
                                      Hello, I am trying to bring back to life my Toshiba 55U7863DG, which has never been the most reliable device - keep on annoying me with its slowness and some random start-up/shutdown issues requiring to unplug the AC. But yesterday it finally said goodbye and decided to not turn on again. Green light is blinking, I've seen this behaviour before and thought that these are some temporary whims again, but unfortunately not this time.
                                      I have checked that my TV is build based on the 17MB130S board, which seems to be quite popular and easy to buy as a used one. Still I would like to ask...
                                      12-02-2023, 01:35 PM
                                      09-06-2024, 05:27 AM
                                    • shahnld
                                      Sony kdl 65xg9505 green amber blinking
                                      by shahnld
                                      Good Day.
                                      I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
                                      i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
                                      green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite...
                                      01-03-2024, 03:05 PM
                                      09-06-2024, 05:59 AM
