Sony KDL-50W815B 3 blinks...
  • PowerAmpFreak
    • 982
    • Sweden
    This Sony KDL-50W815B starts up and shows picture for a few seconds, then suddenly goes to errormode with 3 blinks.
    It has external DC-powersupply.
    Any advice?
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Sony KDL-50W815B 3 blinks...
    Have you checked that the incoming DC supply voltage is not dropping. Power packs do become faulty.
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      Test the external PSU with another reasonably sized load and see if the power sustains or you could us another same sized PSU to test the TV. What is the Output Vdc??...It should be written on the PSU's label....I gestimate about 24Vdc.
      • vinceroger69
        • Mar 2012
        • 6714
        0 no red standby light-check powercord or bad main logic board or power board, check standby volts
        1 red blink not used
        2 red flashes is bad power board, solution replace power board
        3 red flashes is bad main logic or power board, check for standby volts if ok replace main logic board
        4 red blinks- can be LD board or main logic board, check inverter board wires for arcing to ground
        5 red flashes- bad lcd panel connection or internal lcd short- squeeze bezel to locate bad connection
        6 red flashes- backlight issue, bad main board, or power board or inverter boards- check standby volts on power board. "backlight on" volts should be 3-5v from main logic board then 24v to inverter
        7 red flashes- main board over heating, can be short on power board or main logic board
        8 red flashes- main board sp prot, try power reset, update with usb, or replace main logic board
        9 blinks- check fan error, * if TV has fans
        10 blinks- digital board or tuner board * some Sony TVs may not have this board
        11 red flashes- bad main board, bad IC, replace main logic board
        12 red light flashes is tcon error bad T-con board or bad LCD panel, replace tcon board usually
        13 red flashing is backlight balance error bad lcd panel or inverter boards (common) or bal board on kdl-52v4100 only, replace inverter board usually then main logic board
        14 red flashes HFR- bad TCON or Bad LCD panel, replace tcon board. unplug tcon board if tv stays on without tcon board replace tcon board. "como sony tv reparación"
        • PowerAmpFreak
          • 982
          • Sweden
          Thanks for all kind replies.
          Suddenly it started to blink 8 times... Seems like a faulty mainboard
          Wonder if it's worth it to try update FW by USB ?
          • matwan
            Sony XR-55X90J 5 blinks
            by matwan
            I have problem with SONY 55X90J. After several check status is as below;
            1. Running power board as stand alone:
            TCON_12V =~ 12.6V
            EVDD V On Max 24V= 19V.
            2.
            Running power board with TCON as stand alone:
            Effect as below, attched.
            3. When bottom LVDS cable is disconnected no blinks, but of course no TCON 12V and EVDD.
            "I'm almost sure it's a defective panel, but maybe someone has encountered a similar issue on their screen.
            Best regards....
            09-28-2025, 04:26 AM
          • GoodCapDude
            Sony XBR-75X940E intermittent 6 blinks error code
            by GoodCapDude
            Hi everyone. First post on Badcaps!
            I am trying to fix a Sony 940E from 2017 that either starts normally (and works perfectly until turned off) or goes straight to the 6 blinks error code without showing anything on the screen. It is frustrating to know that it can still work perfectly but is barely usable because of the difficulty starting it up. I am willing to try to short the BL_ERR but I would like to avoid that if possible. Does anyone have a view on this? Thanks a lot....
            09-20-2025, 06:07 AM
          • AK_777
            Sony KD-65A1 Repair – 4 Red Blinks Error
            by AK_777
            Hi everyone!
            I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
            Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and...
            02-20-2025, 04:15 PM
          • jchon
            Sony A1e 5-blinks help
            by jchon
            Hi I'm new to trying to repair TVs, but I saw a broken OLED offered for a reasonable price and thought I'd try my hand at it.
            I found the service manual, which was critical to know where to probe.
            https://www.manualslib.com/manual/20...1e-Series.html
            With it I was able to determine that my DKA board was bad, when P_ON#1/2 gets enabled REG_12 on the DKA board collapses. I'm assuming one of the downstream regulators has a short, but I couldn't work out which rail/component and replaced the DKA board entirely.
            Unfortunately the 5-blinks...
            06-28-2023, 11:52 AM
          • Nicktronic
            Sony XBR-65X850D 2 Red Blinks
            by Nicktronic
            I have the subject TV and it will work normally sometimes but suddenly go black and give the 2 red blinks blink code. When this happens, I check the power supply board voltages and all I have is the Standby 3.3V and BL_ERR 2.2V. When it's working normally, all power supply board voltages look normal and stable. I've checked the backlights with a tester and they all test good. I've also read that the 2 red blinks is a faulty power supply board, so could it be throwing up an erroneous BL_ERR?
            Any Sony experts out there that can help??...
            11-19-2023, 06:51 AM
