Panasonic TH-42PZ70B Not switching on solved THANKS
  • Grunder
    • Jan 2016
    • 323
    • south africa
    Good morning, Thanks to Badcaps for helping me solve the problem on my Panasonic TH42PZ70B. The set was not switching on.
    Thanks to Tom & others who thrashed out the problem back in 2012.
    The customer had looked himself and came in with a little tub of screws Photo 1
    Removing of the Y main involved removing a couple of pieces photo 2
    The errant Mosfet as Tom had said was short circuit (H5N2307) photo 3 & 4
    I could not source the component locally, and could not even find a Datasheet for the component on the net.
    I found an old Panasonic Y main pcb with a similar lay out. photo 5. I read Toms advice about the slight differences in parameters of similar devices, but effectively replaced the faulty H5n2307 with a 2sk3995. photo 6
    I have run the set for two hours, and all looks okay. If it returns, I'll have to try source original or refund. photo 7 (sorry sun light/ picture quality)
    I didn't do the upgrade either, reckoning that the part had failed due to ware & tare (set has run for 5 years plus), and not due to old/erroneous drive.
    Thanks, you guys are a wealth of information.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Panasonic TH-42PZ70B Not switching on solved THANKS
    The other SC board or Ymain is out the 50" version of this set I believe. Also thanks for the post these are bloody good reliable Tv's
      by sam_sam_sam
      03-31-2024, 02:12 PM
      by sam_sam_sam
      After all of...
      07-13-2024, 08:14 PM
      by sam_sam_sam
      07-01-2024, 06:34 AM
    • Andre Gilbert
      by Andre Gilbert
      Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
      Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
      11-20-2024, 08:52 PM
    • JDC
      (SOLVED) - Panasonic TH-50PZ80U - No HDMI
      by JDC
      Issue: Panasonic TH-50PZ80U works fine but has no HDMI output.
      Easy solution: replace main board.
      Advanced solution: replace HDMI chip on main board.
      Unless you've got the time, tools and the hands of a surgeon, skip the advanced solution. For you beginners out there reading this, you would need to use a combination of a heat gun, flux, solder, and probably a microscope to succeed. If there is someplace you can send the board in for repair, you can go for that. From what I've read elsewhere, I don't think this TV will even do 720p.
      If none...
      08-10-2022, 06:10 AM
