Asus monitor turns on and off
  • Venomus28
    • Oct 2016
    • 38
    • Albania
    Hello forum
    I have an asus monitor who turns off right after 1 sec, i went to see whats going on and i found nothing unusual on the caps. then i found out some "burning" at the soldering points of the inverters
    Pics below
    Help
  • CapLeaker
    Leaking Member
    • 8183
    Re: Asus monitor turns on and off
    On the last 3 pics I just see excess flux. With alcohol and a toothbrush it will clean right off.
      • 31050
      there are a number of joints that need to be resoldered, and i dont mean the ones with flux on them.
      also the caps are crap (Elite brand!)
      • mariushm
        • May 2011
        • 3799
        The problem is most likely located at the CFFL tubes in the LCD panel. Maybe one of the wires is loose (it got desoldered from the cffl tube due to excess heat) or maybe one of the cffl tubes is too old and uses too much current (normal as they age, the use more power) and the power supply stops itself to prevent overheating.
        In order to inspect the cffl tubes, you'd have to be very careful opening up the lcd panel, it's made up of several layers of glass and plastic sheets and the lcd glass itself is very sensitive to pressure and can crack if you don't handle it properly.
        Here's some pictures of CFFL tubes to get an idea of how they look inside the lcd panel : http://s807.photobucket.com/user/bud...?sort=3&page=1
        • Venomus28
          • Oct 2016
          • 38
          • Albania
          Yes i will do that for sure, but i think there is excess heat that caused that
          • Venomus28
            • Oct 2016
            • 38
            • Albania
            Can you point the ones you think to work on ?
            • Venomus28
              • Oct 2016
              • 38
              • Albania
              Thats really an idea to start on
              I'll do the inspection and i'll let you know
              • Venomus28
                • Oct 2016
                • 38
                • Albania
                I'll keep you posted, thanks friends
                • Venomus28
                  • Oct 2016
                  • 38
                  • Albania
                  Ive inspected the tubes and all looks ok ...
                  • Venomus28
                    • Oct 2016
                    • 38
                    • Albania
                    So I've tested the tubes in another monitor and they work good.
                    Then tried the same monitor with the tube wires not connected and the monitor turned off again.
                    So I think the problem is the power supply.
                    What should I check ?
                    • Dumah Brazorf
                      • Jun 2013
                      • 179
                      • Italy
                      Check the resistance of the transformer's coils.
                      You should remove them from the board.
                      • Venomus28
                        • Oct 2016
                        • 38
                        • Albania
                        Grazie
                        I've measured the 2 transformers of the inverter and one of them doesnt shows signs or life at the part pointed in red lol
                        I'll take it out of the board and power it up and check if the monitor goes off again
                        • Venomus28
                          • Oct 2016
                          • 38
                          • Albania
                          So I took out both transformers and powered up the monitor, same as before. Shut down itself.
                          What could be ?
                          • jondoe
                            • Nov 2016
                            • 547
                            Check Q803 Q802, the mosfet which feeds that transformer, compare the working side with the non working side.
                            • CapLeaker
                              Leaking Member
                              • 8183
                              and IC801
                              • Venomus28
                                • Oct 2016
                                • 38
                                • Albania
                                Its not a backlight problem
                                • Venomus28
                                  • Oct 2016
                                  • 38
                                  • Albania
                                  and IC801
                                  Thank you i will
                                  • CapLeaker
                                    Leaking Member
                                    • 8183
                                    so do the backlights turn on only for a second or not at all?
                                    • Venomus28
                                      • Oct 2016
                                      • 38
                                      • Albania
                                      Yes, they turn on, when i plug the monitor on, for a couple of seconds then off
                                        by momaka
                                        03-15-2023, 10:17 PM
                                      • myth77
                                        ASUS PG27U MONITOR
                                        by myth77
                                        First, i dont work on monitors only on laptops and that also for a hobby. So, i received this monitor in the title and it was completely dead, and power supply when used was going off to a power protection. I found that one of the voltage regulators for backlight GS9238 is dead, so i replaced it and monitor is working fine now. But...on the main motherboard first thing i tested was a main power rail and after power jack there is one mosfet Nikos PD537BA. The thing is when i tested all pins of that mosfet are shorted in between. Now when i plug the adapter the monitor just goes on. I dont think...
                                        03-19-2024, 08:58 AM
                                        ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook 15 Specification for Upgrade or Repair
                                        This specification for the ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD boardview and ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                                        09-07-2024, 02:50 AM
                                        ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook Specification for Upgrade or Repair
                                        This specification for the ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year boardview and ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
                                        ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook CX1 Specification for Upgrade or Repair
                                        This specification for the ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB boardview and ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional...
