My coby tv keeps flashing different colors (red, green,white,blue, black) over & over again. How do i reset it back to normal operating mode?
Coby tftv4028 is flashing different colors
Re: Coby tftv4028 is flashing different colors
Possible EEPROM fault U7 needs replacing.Willing to help but I'm no expert. -
you may need the original remote control as mentioned above you could also try replacing the eeprom with a pre programmed one or failing that if you can find a exact matching mainboard if cheap enough (make sure you match all numbers from your old mainboard and get one from a tv that has the same lcd panel as yours)Comment
by STKR123As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
I wonder if re-flashing the BIOS might be of any use here.
As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,... -
by learnmoreHello Community!
CASE DETAILS
Promblem Signs: Backlight on 1 sec off 7sec > repeat && Red standby light: 1blink, off 3 sec, 2 blinks, off 5 secs, 2 blinks, off 3 sec, restart cycle
13V present on powerboard output. Backlight continues flashing after removing cables to pannel one at a time and even with both disconnected. NOTE: backlight STOPs flashing and remains on when connector between powerboard and mainboard (note Tcon built in) is disconnected.
Tried inserting firmware on USB and left it in for a few hours, but no change
by H34TORecently I've gotten into EC flashing due to my broken laptop(s) and started frantically searching methods for flashing the IT5571E-128 chip on the cheap(due to me beaing a student and not having a job) and noticed that ITE newer chips can be flashed via ISP (In-System Programming) either via SMBus or the KBC (EPP - Enhanced Parallel Port) interface. While these can be achieved with programmers like SVOD4/3 or the RT809H/F those options are WAYYY out of my budget so I was horrified. But recently I stumbled uppon some programmers on aliexpress that claim they can program a variety of ITE chips...06-17-2025, 07:17 AM
YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
I also changed the screen because the PC fell and the screen was broken.
I changed the battery with a new and original battery.
I also had corrosion/oxidation on the... -
by YellowJacketHi folks,
DELL Latitude 5410, board number FDZ41 LA-J371P Rev: 1.0 (A00), schematic uploaded in different post, here is the link --> https://www.badcaps.net/filedata/fetch?id=3484415
When I connect it to a power ( DELL round charger, or USB-C ), LED on the power button starts flashing white, and the laptop doesn't do anything ( flashing slows for a very brief time in time when I press it, but it continues again ). Battery is not charging. While the charger is connected, I have few voltages present, but some of them are fluctuating, see attached pictures.
All I was able... - Loading...
