Toshiba 50l1350u low power to LED
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Toshiba 50l1350u low power to LED
    Originally posted by budm
    Yep, two boost converter circuits, you can see two inductors (LL1, LL2), two Power MOSFETs (driven by the OB3372), Two boost DiodeS DL2, DL4.
    SMD MOSFET QL5, QL1 (PWM driven) are the return (Cathode) lines for the LED string returns (two set of LED strings).
    If you can find the application notes circuit of the OB IC, then circuit will probably be close to what you have on your board. The OB IC may be damaged when the MOSFET went out.
    The manual in post #9 has a similar led driver stage.
      Originally posted by dick_barton
      P0920ATF data sheet
      I just look at the service manual, thanks.
      • Gundulf
        • Mar 2013
        • 13
        • puerto rico
        i missed this post
        • Gundulf
          • Mar 2013
          • 13
          • puerto rico
          SMD MOSFET QL5 (3?), QL1 (PWM driven) are the return (Cathode) lines for the LED string returns (two set of LED strings).
          The mosfet is BAD So from here What to do? should i just get a replacement board or will it be worth it to try and replace the mosfet and the resistors and see if the IC is working? what would you guys do?
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            Check how much a replacement circuit board is with Shopjimmy and compare the price against the cost/availability of the components and how good your soldering skills are.
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              #26
              You could contact these people and see if the parts are suitable for your set.
              http://www.tvtechparts.com/PK101W0-R...54_p_5215.html
              • Gundulf
                • Mar 2013
                • 13
                • puerto rico
                #27
                Thanks for the link Dick, that will be the option to go if the Ic is damaged hope not haha. I found this
                http://www.st.com/content/ccc/resour...CD00000701.pdf to replace the http://products.niko-sem.com/images/...8769732102.pdf
                would it be fine with that mosfet?
                thanks for the help!
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  #28
                  The TO-220FP would probably be OK. It has the voltage, current ratings and same pinout and in an isolated package. I suggest you check the physical size against the P0920ATF.
                  • Gundulf
                    • Mar 2013
                    • 13
                    • puerto rico
                    #29
                    Hello Guys
                    After a couple weeks of wait, and having enough time to sit and do it, finally i got the resistors and the mosfets and replaced them. Now i have no power
                    I went ahead and replaced both mosfets, even though one was okay. So i'm not sure if by removing the one good mosfet(asuming the ones i got are not good replacement) would cause me the no start.
                    i replaced the P0920ATF with IRF630.
                    Anyways i took the readings out of this plug
                    and i have:
                    0v on 15
                    5.17v on 14(has no cable)
                    0v on 13
                    4.40 v on 12
                    3.20v on 11
                    5.17v 10
                    and 0v on 9-1
                    what could the problem be now? lol I will later replace the good mosfet back into place and see if at least i recover what i had before(power on but no leds) Any ideas?
                    • PantherDave
                      by PantherDave
                      Hi all!
                      05-29-2024, 02:01 PM
                    • GLISIT
                      by GLISIT
                      01-16-2025, 02:29 PM
                    • stylishconsultant
                      un60j620dafxza - Samsung No Display Problem
                      by stylishconsultant
                      Hi All,
                      Need help.
                      I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
                      So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
                      problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
                      might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
                      09-04-2024, 03:26 AM
                    • ju123
                      Toshiba Satellite C50-A won't power down
                      by ju123
                      Hi guys,
                      So, I've been racking my brains on this one.
                      I have a Satellite C50-A which I'm repairing for a friend.
                      I recently replaced the main board due to failure.
                      Following this, absolutely everything works perfectly, except for the fact it won't power down.
                      Initially, shutting down via Windows would shut the OS down, screen would turn off (noticed the lighter black go to what looks like the darker black powered off screen as though the backlights have powered off), however the laptop was still running internally with a spinning...
                      01-07-2022, 04:40 PM
                    • robgerr
                      Toshiba L50-B-1Q0 (Main DABLIDMB8E0 REV:E) no power on
                      by robgerr
                      Good morning forum. This laptop comes into my laboratory with the defect that it won't turn on. By connecting the bench power supply I have an absorption of 1.56A (battery charging), I disconnect the battery, I have an absorption of 0.01A. I give the power on but it doesn't react. I check the mainboard and I notice the Isl88732 charger with oxide and a little burnt between pins 7-8. I remove the charger, clean the pads and solder another ISL coming from another identical board. I also find a bit of oxide in the power button connector. I clean the connector, clean the flat that goes to the power...
                      12-07-2023, 06:22 AM
