Hello guys. My toshiba 50l1350u tv has a problem. I can shine a flashlight at it and get to see the display. So i thought i had dead LED's and took it apart and realized the LED's are all functional(powered each strip(12). So it became evident i had no power to drive them. Should have checked that first
anyways i pluged all back and read 73 volts on the Led outputs. it has 6 strips of leds divided in 2. Both outputs read 73 volts. With leds plugged in. At night i turned the tv and was able to operate it(just the menu) with the remote without the need of a flashlight, because the leds appear to turn on with the 73 volts just too dim to be of any use. I guess im supposed to have about 150v+ on these outputs, so something is wrong with my power supply. Everything looks well, nothing is blown, no bulged cap, no burnt smell. The Tv maybe had 1 month of use( i installed it on a clients house guest room and really saw not much use) But i have no idea where to look for a culprit. Any light will be most welcomed.
thats a picture of the board in question.
anyways i pluged all back and read 73 volts on the Led outputs. it has 6 strips of leds divided in 2. Both outputs read 73 volts. With leds plugged in. At night i turned the tv and was able to operate it(just the menu) with the remote without the need of a flashlight, because the leds appear to turn on with the 73 volts just too dim to be of any use. I guess im supposed to have about 150v+ on these outputs, so something is wrong with my power supply. Everything looks well, nothing is blown, no bulged cap, no burnt smell. The Tv maybe had 1 month of use( i installed it on a clients house guest room and really saw not much use) But i have no idea where to look for a culprit. Any light will be most welcomed. thats a picture of the board in question.
Field Effect Transistor. P0920ATF
