Toshiba L50-B-1Q0 (Main DABLIDMB8E0 REV:E) no power on
  • robgerr
    • Apr 2012
    • 70
    • Italy
    Good morning forum. This laptop comes into my laboratory with the defect that it won't turn on. By connecting the bench power supply I have an absorption of 1.56A (battery charging), I disconnect the battery, I have an absorption of 0.01A. I give the power on but it doesn't react. I check the mainboard and I notice the Isl88732 charger with oxide and a little burnt between pins 7-8. I remove the charger, clean the pads and solder another ISL coming from another identical board. I also find a bit of oxide in the power button connector. I clean the connector, clean the flat that goes to the power button, connecting the power supply I find the 3.3v on the power button pins which drop to 0v when I press the button. I tried to flash two bios downloaded from your site, also reprogrammed with the official Toshiba one which I cut since it was bigger but nothing to do. Even the small 24xxx spi but nothing. I didn't find short on the main coils.
    I only have the 3.3v and 5V voltages.
    ISL88732: (no battery connected)
    pin 1 5v
    pin 2 3,93v
    pin 3 3,18v
    pin 4 0v
    pin 5 5v
    pin 6 0v
    pin 7 1,42v
    pin 8 0v
    pin 9 3,34v
    pin 10 3,34v
    pin 11 3,34v
    pin 12 0v
    pin 13 3,34v
    pin 14 0v
    pin 15 1,33v
    pin 16 0v
    pin 17 1,25v
    pin 18 0v
    pin 19 0v
    pin 20 0v
    pin 21 5,09v
    pin 22 18,68v
    pin 23 1,23v
    pin 24 1,20 with little oscillation
    pin 25 4,77v
    pin 26 5,09v
    pin 27 19,20v​
  • mon2
    • Dec 2019
    • 14468
    Would you have the link to the schematics? Post the link only if the schematic is in the schematic forum.
    Are you sure of this part number (ISL88732) on your charger IC? This is an AC voltage based charger IC.
    • robgerr
      • Apr 2012
      • 70
      • Italy
      Hi Mon2 and thanks for replying. I downloaded the schematic but I don't remember where. I'll send you a photo of the oxidized component IC charger replaced (picked from other same main board)
      • mon2
        • Dec 2019
        • 14468
        Ok. Can you post a partial view of the schematic that shows this charger ic. Even better if you post the full schematic in the schematic forum and link it in this thread.
        • robgerr
          • Apr 2012
          • 70
          • Italy
          This is the schematic I found, but unfortunately it doesn't match serigrafy.
          https://www.badcaps.net/filedata/fetch?id=2052989​
            09-06-2024, 05:27 AM
            09-06-2024, 05:59 AM
            09-06-2024, 05:33 AM
