Sanyo DP46849
  • rickybennett
    • Jun 2012
    • 26
    • usa
    Sanyo DP46849
    Any one know if there is a known issue with this tv ?
    i got pics of the label and tv for not that is all i have to work with the tv belongs to a friend they say it dont work idk what its doing all i know is they say its hard to turn on and now they want to use one of my spare tvs
    so any one know any thing about this tv? and i will post the pics but the tv is mounted to the wall so the pics are not that good.
  • cj_reha
    Mystery 80s Sanyo cap - perhaps polymer?
    by cj_reha
    Hey all I've been working on a 1984 Sanyo 27" color TV which had a smattering of bad caps in the video switching circuit. I found this oddball little 1uF 25V cap which looks to me like an early polymer, but I can't find concrete info proving it. I know Sanyo was a big player in early polymer cap development and this is the time period where they were just getting on the market, so I'm wondering if anyone has crusty old datasheets that could help identify it and determine if my suspicions are right? It has the same epoxy end seal and font/formatting as some old stock Os-Cons I've got laying...
    01-06-2023, 09:24 AM
  • jasonbay13
    Dell Inspiron 15-3521 ~ LA-9104P ~ No Power - corroded board with pics of damage and some voltages
    by jasonbay13
    it was working yesterday, i opened it up and saw this mess. boardview and schematic uploaded for convenience.
    PU200
    pin 17 vreg5 = 0v ~ solder joint was corroded and flicked right off with my probe, was able to get clean and reflow, rest look fine.
    pin 8 vreg3 = 0v
    pin 13 en = .2v
    pin 1,6 entrip1,2 = 0v
    b+ and b++ = 19.5v
    +5valw = 0v & 25+ohm to ground
    +3valwp = 0v & 25+ohm to ground
    i cleaned the board up just a little and can get more pics.​
    where should i be looking? thx...
    09-25-2025, 10:54 PM
  • toddw65
    Sanyo DP5834 - Gray Screen
    by toddw65
    Hey All,
    I have a Sanyo DP5834 that did have an issue with the backlights, but I disassembled the unit and repaired the LED strips by resoldering all of the connectors. Now I've reassembled it and I have backlights and sound, but a grayish screen. I can tap on the screen and see that it's on, but no picture. All voltages seem to be correct on the power board.
    Based on the LCD Flat panel TV troubleshooting guide by Bud Martin, I'm thinking the T-Con has failed because I'm getting 12v both into and out of FP1 on the T-Con. Am I on the right track?
    Thanks,...
    10-31-2024, 10:37 AM
  • hugocarmo
    Sanyo VHR-D4710G VCR no sound.
    by hugocarmo
    Hi again guys.
    Today I have a problem with this Sanyo VCR.
    I bought it online, It worked sometimes.
    I recap the Power supply and it started working fine.
    Image is perfect and all digital effects too.
    All of a sudden it stopped outputting sound. I checked for dried solders an all boards and soldered when needed, no fix.
    I have no sound on playback, on tuner, or aux in.
    On symptom I noticed is when it was working fine, the HI-FI led was on when I power up the VCR, now is OFF, A-B leds are on but when I put a tape they go off.
    On one of the sound processing...
    01-23-2024, 12:58 PM
  • m4a2t0t
    50's Sanyo monitor
    by m4a2t0t
    What type of caps can I use to replace these Rubycon (K) caps? Can I use a film cap? I cant find any aluminum electrolytic caps that go that low. They are .033 uf and .047 uf
    06-16-2025, 07:04 PM
