Kiamo lcd 32 hdtv
  • fpegman
    • Mar 2011
    • 16
    • Spain
    Kiamo lcd 32 hdtv
    I have a problem with a KIAMO LCD 32 HDTV it appears to be locked ouit none of the buttons on the front panel will work there is a red light showing when plugged in I have no remote and think the child lock has been activated can anyone help please
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    Re: Kiamo lcd 32 hdtv
    is there any other model numbers for this set it maybe on the back on a sticker.
    • fpegman
      • Mar 2011
      • 16
      • Spain
      This is all that is on the back panel sticker
      KIAMO
      Ser No 06 10 17 05620
      Model LCD32HDT K
      • lallollas
        Acer chromeBook c733-c3uy Locked need help
        by lallollas
        chromebook locked without google account i alreadu edit rom and change value enrol 1 to 0 and still locked need help
        model n18q5...
        04-09-2024, 08:14 AM
      • LEEDASH
        Aiwa TX-110 Tuner Buttons
        by LEEDASH
        Hello all, Aiwa TX-110 Tuner got out of storage and the buttons was held in by some gloop, What glue would you use to restick these buttons (they are no snapped off)
        Thank you
        05-07-2024, 02:41 PM
      • idegenerated
        HP 800 G6 Locked BIOS (with Sure Start)
        by idegenerated
        Thanks for your help in advance. I have an HP 800 G6 that has "Protected by HP Sure Start" on boot. It has a locked BIOS that I'm trying to remove with RCUnlocker, but even after unlocking it and reflashing, it doesn't appear to work. The password is still prompted when I attempt to enter the BIOS.
        Using NeoProgrammer in Windows and a CH341a I was able to read two 16MB BIOS chips, a GD25Q127C and a GD25Q128x like this thread here: https://www.badcaps.net/forum/troubl...-desktop-mothe...
        03-11-2024, 09:49 PM
      • opensourcefan
        Lenovo X1 Yoga 1st Gen (model - 20FQ) with a locked BIOS
        by opensourcefan
        Hey all, I have a Lenovo X1 Yoga 1st Gen (model - 20FQ) with a locked BIOS. I would like to unlock it.
        Currently I have it apart in all its glorious bits looking for the security eeprom that I can't find. Plan was to jump it. Next step I think is to pull the BIOS IC and flash a decryption file to it?? I'm a bit confused on that process.
        1. Pull the BIOS IC,
        2. Read and save the original locked file
        3. Flash the decryption file
        4. Install and boot up and remove password from BIOS
        5. Remove BIOS IC again
        6. Flash Original locked...
        11-19-2022, 06:18 PM
      • Modify_inc
        Locked Setup Fails to Unlock with Correct Password - Inspiron 11 3185
        by Modify_inc
        I have a Inspiron 11 3185, and in the BIOS setup under Security it shows "Locked Setup", which limits pretty much everything in the BIOS. I'm using bios-pw.org to generate the codes for the hash, but they never work for the Locked Setup password. The codes generated for the System password and the HDD password work fine, but the code for the Locked Setup password always fails. I don't understand, if it works for the first two, why is it not working for the Locked Setup p/w? Since I can't disable it, anytime I reboot, even after a Windows update, I have to go through the hassle of generating...
        11-02-2021, 11:14 AM
