Panasonic plasma noise filter
  • Georgia088
    • Sep 2014
    • 109
    Hello and thanks in advance for any help. I have been working on a tv and getting advice from another thread on this forum: https://www.badcaps.net/forum/showth...047#post700047
    However, I felt like I should start a new thread.
    The noise filter on the tv I am working on no longer has 120v coming out of it that it needs to power the power supply board. I purchased a new one "Panasonic Plasma Noise Filter K2AHYH000043". However when I test it in has no power coming from it either when plugged in.
    I bypassed it and my tv comes on and works. Are there different versions of
    Panasonic Plasma Noise Filter K2AHYH000043 bc the one I ordered has different numbers than the one that came in the tv originally.
    Will it harm the tv to permanently bypass the noise filter and connect power to the main board?
    Thanks!
  • Hombre
    • Jul 2013
    • 231
    • Croatia
    Re: Panasonic plasma noise filter
    It should work fine without it.
    Can you post here pictures of both of them (sticker close-up).
    Maybe try to change the power cable, maybe the wires inside are damaged because of the bended cable, but as i said it should work fine without it.
    • R_J
      • Jun 2012
      • 9561
      Did you check continuity from a/c input to the output? there are only a couple coils in each line, maybe try a different a/c cord, sometimes the pins in the cord are further in than others so they don't make contact with the filter pins.
      I don't think I have ever had to replace one.
      • jm1234
        Panasonic plasma TX-P42ST50 - 6 blinks
        by jm1234
        anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
        It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
        I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
        I checked that board for any obvious faults...
        05-22-2024, 06:59 AM
      • stecos
        Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
        by stecos
        Hi everyone!
        I happened several times, in the search for help from the web, to consult this very interesting forum.
        So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
        Having said that I come to the gist of my post on the forum as the title suggests.
        For my passion for technology I'm now collecting several...
        11-28-2022, 11:39 AM
      • cloo
        Panasonic ZT60 plasma tv with strange behavior and 8 blink code
        by cloo
        I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
        It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
        So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
        After doing a factory reset this problem was gone and the picture was back to...
        01-06-2025, 06:02 AM
      • Alicat
        Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
        by Alicat
        Stopped by this site trying to fix my parents Panasonic Plasma TV.
        Model number is TH-50PZ85U
        Power comes on and the red power light stays on solid.
        Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
        I also hear a few clicks.
        I also think my parents said there was a thunderstorm and the TV failed after that.
        Section 6 in the service manual talks about power and no screen,...
        10-30-2024, 10:09 AM
      • Lintesir
        Panasonic P42S30 Plasma - Pink sparkles
        by Lintesir
        My parents' Panasonic P42S30 died recently, and they asked me to have a look at it. I was able to identify the SN-board as the culprit, as it was shorted. After removing Q401, Q402, Q421 and Q422 the short was gone, so I replaced these components and that got the TV working again. However, when testing the tv a bit, I noticed quite bad pinkish sparkles on some colors. For instance the greyish bar on this forum seems to trigger it quite badly. I made a fullscreen test picture with only that color, with the below result.
        There is about a 5cm high region at the top without any sparkles,...
        07-26-2024, 03:16 AM
