another bn44-*****
  • merkin
    • May 2010
    • 57
    another bn44-*****
    specifically bn44-00267b in a sammy ln52b530p7fxza
    history:
    two years ago the tv would not turn on. when you turned on the power, the red stdby indicator light would go from solid to flashing a couple of times and then back to solid.
    i pulled the power supply board and replaced the following caps:
    cp814
    cp8?? (next to dm801)
    cm807
    cm808
    cm811
    cm818
    cm819
    cm820
    (i think that was it)
    problem was fixed..
    present time:
    issue has returned, but at this time its intermittent. sometimes the tv will power on and sometimes it will not. when it does power on, after a while the picture will go black (off automatically) and the stdby indicator light will come on, and then after some time the tv will automatically come back on.
    here is the psu:
    http://www.shopjimmy.com/samsung-bn4...upply-unit.htm
    would like to get to the root of the issue this time around. got scopes, meters and other test equipment at my disposal, but need some insight on what to test.
  • CapLeaker
    Leaking Member
    • 8116
    Re: another bn44-*****
    heat up the caps with a hair dryer and see if the tv turns on without hickups.
    check the BLon pin and see if you loose voltage (when the backlights turn off).
    • merkin
      • May 2010
      • 57
      thanks ill try when i get home from work tonight.
      any insight on theory behind the tests you want me to run?
      also i see a lot of schematics posted for bn44 psu types, but not one specific to mine..if anyone has the bn44-00267b schematic please share. thanks.
      • R_J
        • 9535
        I would check the board for poor solder connections, mostly the transistors etc.that are attached to heatsinks, look at them with some magnification or just resoler them.
        • CapLeaker
          Leaking Member
          • 8116
          My theory? If it is a capacitor problem, the tv should work fine one the caps are warm, as it lowers the ESR.
          BLon is generated on the main board. If you lose BLon, the backlights go out. If you don't lose BLon, look at the inverters. But we didn't get that far yet. RJ has also a valid point to check for cold solder joints.
          • merkin
            • May 2010
            • 57
            after removing and re-connecting the psu, i plugged in the tv and turned it on. its been on for almost 24 hours.
            what pin on cn801 is the BLon pin?
            • kevinm34232
              • May 2012
              • 1884
              What is the main board part #?
              • merkin
                • May 2010
                • 57
                cant check now, but its an input on the psu anyway..see cn801 from the link in the first post. pin23 maybe?
                • kevinm34232
                  • May 2012
                  • 1884
                  Well it sounds like you are not just losing the backlight but the TV actually shuts off?
                  • CapLeaker
                    Leaking Member
                    • 8116
                    BLon comes from the mainboard and it turns the backlights on. So verify that it is still present when the backlights are out. I don't know exactly what pin it is, because I can't zoom the pic good enough to read it.
                    Also check the PSon pin. That also comes from the main board.
                    • merkin
                      • May 2010
                      • 57
                      are you clicking on the photo in the link?
                      its hi-res.. you can zoom in and see the pinout.
                      • kevinm34232
                        • May 2012
                        • 1884
                        My point is if the TV is not coming on, standby light flashing, eventually turning on, you may have a main board problem if your part # is the same as the one below or similar, very common issue.
                        http://www.ebay.com/itm/131529336351
                        • CapLeaker
                          Leaking Member
                          • 8116
                          My tablet won't let me.
                          • merkin
                            • May 2010
                            • 57
                            1. PS
                            2. sync
                            3. SB
                            4-6. GND
                            7,8. 13V
                            9-12. GND
                            13-16. 5.1V
                            17,18,20. GND
                            19,21,22. 13V
                            23. INV-ON
                            24. I-PWM
                            25. E-PWM
                            26. GND
                            27. 5V_DET
                            28-30. GND
                            • CapLeaker
                              Leaking Member
                              • 8116
                              PS = PSon, INV-on=BLon
                              See what happens to all those pins when the TV is working fine and again when it failed. Use pin out name and the voltages measured.
                              • C152Heavy
                                by C152Heavy
                                Summary for TL-DR readers:
                                • VCC pin (18) of PFC...
                                01-11-2023, 02:53 PM
                              • mrmonza
                                Power board problems bn44 00859a
                                by mrmonza
                                Hello. I have a samsung ue55ju6875u that hade led backlight problem and the cause was a glitchy conector to the led feedstrip.
                                The problem now is that the wire pin 1 on the led connector broke lose an shorted against the chassie and now the tv is dead, no red light when plugging in the power cord before the short the relay clicked and it was a red light for a few seconds then it blinked 5 times.
                                The power board is an bn44 00859a can anyone point me in the right direction what to check to solve the problem or maby someone have an electrical diagram for a bn44 00859a....
                                12-09-2023, 08:57 AM
                              • kogi
                                Samsung bn44-00384a (unknown fried IC)
                                by kogi
                                Hello I am trying to repair the power supply board from Samsung bn44-00384a (date 2010) and I am trying to identify one chip with printed batch number and not the actual name of the IC.Maybe you could help me idetify the chip?
                                i read something like 2560D but google shows nothing.
                                07-15-2025, 12:27 AM
                              • _max_
                                Hisense H60N5705 automatically switches off
                                by _max_
                                Hisense H60N5705 installed in a conference room, turns off automatically a few minutes after being switched on.
                                Problem occurred suddenly, during a video conference. Switched on again by the remote control, it continued to work for a while and then switched off again.
                                Power cable and HDMI cable checked.
                                No changes by connecting the TV to another source but, even if it is left on the OSD menu, it stays on for a few minutes and then switches off.
                                So they took the TV (a 60' which is not easy to handle) to the lab and asked me to check it.
                                03-07-2025, 06:14 AM
                              • intercepter
                                BN44-00598A shematic or part list?
                                by intercepter
                                Hi,I have damage on BN44-00598A.
                                I need two mosfets 13NM60N and ic SEM3040 but other damaged unknown part is:
                                QP805
                                RP849
                                DP805
                                DP806
                                DP807
                                RP848
                                QP804
                                Thanks.
                                01-18-2025, 08:35 AM
