Samsung PS43F4500 - Identify Component
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    I would very much appreciate your help in obtaining the service manual for this model.
    There is a fault on the combined Y(Buffer/Main) board with a R5080 burning up and its solder pads overheating and starting to carbonise the circuit board. I cannot read the resistor's original value.
    Even if I replace R5080 the chances are that there is likely to be other problems causing it to overheat which will need to be found and so a diagram would be extremely useful.
    Vscan = 80 ohms to ground so suspect there is an issue here.
    Many thanks in advance.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Samsung PS43F4500 - Identify Component
    Close up of the resistor bud ? Cant seem to find the Dia for this board.
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      Here it is, the heat has faded the colour banding.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Does it go into the adjustment pot ? Cant find a thing for this board ?
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          Hello ReeceyBurger123,
          One end of the resistor connects to the ground plane and the other end to one pin of the transformer alongside.
          • Hamie
            • Apr 2014
            • 1383
            I've got one of these boards. Give me a minute.
            • Hamie
              • Apr 2014
              • 1383
              Red, black, yellow, gold.
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                Hello Hamie,
                That's brilliant. Thanks very much for your help which is very much appreciated.
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  Hello Hamie,
                  Out of curiosity would you be able to measure the resistance between Vscan to ground so I can compare my reading.
                  • Hamie
                    • Apr 2014
                    • 1383
                    Looks like it charging a cap. Goes to around 20m ohms then OL then starts to fall.
                    • dick_barton
                      • Aug 2015
                      • 6643
                      • Wales
                      Just checking the resistance and it's back up to a few K's of ohms so looks OK.
                      Powering back up the set and the area under the resistor is still arching over even though I had scraped away as much carbon as possible without losing the pads.
                      Have found a cheap replacement board and have ordered it.
                        One end of that resistor is not connected the + leg of the caps?
                        • Hamie
                          • Apr 2014
                          • 1383
                          Sorry I misread that earlier, thought you'd asked for vs to ground.
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            You should check things like the transistors and driver Ic of that tranny for short circuits just to be safe.
                            • dick_barton
                              • Aug 2015
                              • 6643
                              • Wales
                              Just a quick suggestion. Looking at the ends of the resistor, one leg is becoming quite tarnished and it would be worth cleaning and soldering the top solder pads so it doesn't burn through as it has on my board.
                              • ReeceyBurger123
                                Never Give Up !
                                • May 2014
                                • 7325
                                • Britain
                                Yes solder the top pads, I had to do so on a burnt sammy sustain board as well,helps the solder flow through better. Will post image db.
                                • ReeceyBurger123
                                  Never Give Up !
                                  • May 2014
                                  • 7325
                                  • Britain
                                  Before soldering on a Q96 Ysus board I did ages ago:
                                  • ReeceyBurger123
                                    Never Give Up !
                                    • May 2014
                                    • 7325
                                    • Britain
                                    After, looks loads better good solder joint as well. Might be best to do Db:
                                    • dick_barton
                                      • Aug 2015
                                      • 6643
                                      • Wales
                                      Would anyone have the schematic for the power supply in this set which is BN44-00598A Rev 1.1
                                      I have the following voltages on CN4009.
                                      The OUT-A voltage of 79V was given in another thread on this site for this set, however it measures only 12V on this power supply.
                                      VA & VS both start at their correct values as given on the panel label and then drop towards 0V.
                                      Sound plays fine and set responds to remote control.
                                      • flocko
                                        • Nov 2012
                                        • 1121
                                        Check across the three green caps for shorts and the four SMD Fets to the rear of board . If found to be shorted a new board could workout cheaper than repair ? pick them up for under £20
                                          09-07-2024, 05:50 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
                                          Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ-K01DE boardview and NP930XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 06:20 PM
