Sharp LC-70LE757U 3D Not Working
  • farcwarts
    • Oct 2016
    • 17
    Hoping someone can help me with my Sharp LC-70LE757U. My tv is only 1 1/2 years old, barely out of warranty. The 3D feature had been working fine, but now it wont work. When I perform the built in 3D test, the images just will not converge to make 3D. My son has the exact same tv model and his works just fine with the various 3D glasses I am using to test mine, so the issue is absolutely the 3D on my TV. I called Sharp and they walked me through a soft and a hard reset of the TV but it did not solve the problem. I just tried a test using non-battery powered 3D glasses to help figure out if the issue was a bad IR transmitter but that did not work either so it seems that the issue must be elsewhere, perhaps on the motherboard or TCON. Has anyone else encountered this issue and know what the solution is? The picture and sound of the tv in 2D mode is perfect and I really love this tv, but was really hoping to be able to watch 3D on it again.
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Re: Sharp LC-70LE757U 3D Not Working
    I doubt this is the problem but I have a Samsung 3D set.
    I need to switch my set to 3D mode and then using the bluetooth glasses, have them connect to the set which then shows that they are connected. This is normally after 30 sec or so.
    Also the 3D format of what you want to watch must be the correct format. I normally use my laptop (connected to my tv) and look for Youtube 3D side-by-side video clip to test my set.
    • farcwarts
      • Oct 2016
      • 17
      Thanks for getting back to me. The 3D feature of my Sharp was working fine for over a year using the same glasses that are still working on the same model 3D TV that my son owns so whatever the issue, it is definitely something with my TV that has gone on the fritz. I am using the 3D test on the TV itself so that I was able to rule out the issue being with the broadcasting from the blueray player.
      • dick_barton
        • Aug 2015
        • 6642
        • Wales
        There's this information
        • budwich
          • Jul 2015
          • 3097
          hmmm... as suggested, ensure you have checked that the settings are correct and someone hasn't "accidentally" played with them.
          thinking on this more... since you have access to another "working set", try this test on the working set. Use your glasses, put the working set in 3d mode and "test mode". Ensure that you can see a "3d" image. Now block the emitter at the set (tape or otherwise)... what do you see? Does it look like the image on the non-working set? IF so, then you have likely found the area to focus further attention on... ie. the emitter and supporting circuitry. IF the image doesn't look like that on your non-working set, then you have likely some other issue / area of problem.
          • farcwarts
            • Oct 2016
            • 17
            Thanks. Do you know where I could find the repair manual for the Sharp Aquos LC-70LE757U? I did an internet search but could not find it. I tried the recommendations that were listed on the thumbnail with no success but I do appreciate the link so thanks.
            • dick_barton
              • Aug 2015
              • 6642
              • Wales
              I found this earlier.
              • farcwarts
                • Oct 2016
                • 17
                Thanks. I just spotted a suggestion from Budwich to test out the 3D glasses on my son's working TV and block the IR sensor. I just tried that and even with the IR sensor covered over, I still got perfect 3D on my son's TV using the battery powered 3D glasses. I was not expecting that result as I would have thought that the battery powered glasses needed to receive an IR signal to provide 3D viewing but not so. Perfect 3D on his TV. The images are the same as on mine in test mode, with the balloons having a ghost image to the rear left and rear right of the solid balloon when the glasses are off but on his working TV, with the glasses on, the three images of the balloon all merge to form the 3D effect but on my TV, the two ghosted images stay ghosted behind the solid balloon when I put on the glasses.
                • farcwarts
                  • Oct 2016
                  • 17
                  Thanks for posting the manual but unfortunately that is the owner's manual that I have with the TV. I am hoping that somewhere there is a link to the technician's service and repair manual. I found that for other models of the TV but not the model of I have.
                  • budwich
                    • Jul 2015
                    • 3097
                    where are you doing your "blocking"... more specifically exactly what are you blocking and what are using to block? Your "result" is surprising... but I don't know alot about 3d.
                    looking for a manual... you need to broaden your "search" as sharp and others don't publish "specific model" manuals, they put them out as a "family" (ie. 40,50,60,70, etc) so looking too specific will likely not get your result.
                    further hmmm... what model of glasses are you using?
                    • farcwarts
                      • Oct 2016
                      • 17
                      I am using the Sharp glasses that came with the TV. I used a book to block the IR sensors on the front bottom of the TV. The book successfully blocked the sensors as I had to move the book away to use the TV remote to access the test menu and then I put the book back in place after selecting the 3D test. The results surprised me as well.
                      • dick_barton
                        • Aug 2015
                        • 6642
                        • Wales
                        Are the glasses Bluetooth (Sharp AN-3DG40)?
                        • farcwarts
                          • Oct 2016
                          • 17
                          I don't believe so. They are model AN-3DG20-B. No mention of Bluetooth on the box.
                          • budwich
                            • Jul 2015
                            • 3097
                            hmmm, i don't think that's how it works. The emitter is sending a signal from the tv that glasses receiver and sync with. I don't think its the IR receiver for the remote which is kind of the opposite direction... just my guess. :-)
                            just to be sure... "geek" your glasses (careful of the lens) to block the receiver.
                            • dick_barton
                              • Aug 2015
                              • 6642
                              • Wales
                              The link with the 3D glasses could be Bluetooth or RF. The AN-3DG20-B glasses appear to use RF.
                              • budwich
                                • Jul 2015
                                • 3097
                                if true... then perhaps you have significant rf interference happening in your watching area causing issues... any new LED lights installed lately... other lighting changes, some other electronics in the room?
                                I haven't found whether the 757 uses both types of "sync systems" (ie. rf / ir).
                                The on-line manual that I see for the glasses indicate that they are IR based with receivers in the side / temple area.
                                • farcwarts
                                  • Oct 2016
                                  • 17
                                  I just looked all over the front of the TV and only see the two dots for IR sending.
                                  • budwich
                                    • Jul 2015
                                    • 3097
                                    OK... but then block the signal at the glasses. Again, see if things change with the "test" at a working system.
                                    Another check... what indication do you have on the glasses that they are "ON" and functioning.... ie. light. I see a "low battery" indicator. Is that indicator "on"?
                                    I see that the glasses automagically turn off after 10 mins of no signal... what / how is that indicated?
                                    • farcwarts
                                      • Oct 2016
                                      • 17
                                      Thank you again for your help. I did tests with two fully charged sets of glasses that had previously worked just fine with my tv and still work fine with my son's same model tv. I covered the IR sensor on the glasses and the 3D did not appear when testing the glasses with his tv but as soon as I uncover the IR on the glasses, perfect 3d appeared, as expected. On my son's tv I noticed that the ghosted balloons are only slightly to the left and right behind the solid balloon when viewing the test screen without glasses or when covering up the IR sensor on the glasses. But on my tv, the ghost balloons appear to be further out on both sides behind the solid balloon. To me the issue clearly rests inside my TV, and I think it is whatever board the 3D function rests on, but I could be wrong as I am guessing.
                                      • dick_barton
                                        • Aug 2015
                                        • 6642
                                        • Wales
                                        This is where I found the information saying they were RF but I would have to agree with you that your testing indicates that they are IR
                                        http://quantum3dglasses.com/sharp-an...11-3d-glasses/
                                        • thetonywarren
                                          TCL 43S435 NO BACKLIGHT ISSUE, LEDS TEST OK
                                          by thetonywarren
                                          I have a TCL 43S435 with no backlights. I contacted ShopJimmy and they said power supply. I got replacement power supply, but still doesnt work. I have confirmed that there is an image with flashlight test. I have also verified that the led strips work when I probe them with LED tester. Any ideas would be helpful. I am also geting a double blink on the status led when trying to turn it on......Nothing on the power supply looks suspect, and caps look ok. Where should I start to test......Thanks!...
                                          04-23-2025, 10:48 AM
                                        • claytongarcia
                                          Issue with Sharp LC-42SB45U
                                          by claytongarcia
                                          I recently got a model Sharp TV, and I've noticed that the green power LED is flashing without any specific pattern. Additionally, there appears to be no voltage coming from the power board. I haven't observed any leaking or bulging capacitors, although the top of the larger capacitor doesn't seem to be perfectly flush with the jacket—if that makes sense.
                                          Has anyone dealt with this issue before?​
                                          03-10-2025, 07:27 PM
                                        • leorivers
                                          Issue with Sharp LC-47SB57UT
                                          by leorivers
                                          I bought Sharp LC-47SB57UT 6 years ago. I had to have a vhf antenna to pick up one local station(koco channel 5 OKC). It has worked great up until a week ago. Sometimes I couldn't get channel 5, now I can't receive it at all. I can hook up a digital convertor box I have from another tv and can receive channel 5.
                                          I think the antenna and cable is ok. I doubt that this would be the tuner board or possibly something else.
                                          Any ideas where I should start?​
                                          10-24-2024, 03:11 AM
                                        • YellowJacket
                                          SHARP LC-32CHF5111K - stuck at color test mode
                                          by YellowJacket
                                          Hi friends,
                                          TV has stuck at - as I googled the term - color test mode. Slowly flashing colors white, red, green, blue, black, over and over again. I tried some hints from internet, like pressing some remote buttons, but nothing worked. I also tried factory reset for Sharp TVs => "while holding vol– & input buttons on tv plug in set when “k” appears push vol– & chan- " , but TV doesn't even start during buttons pressed.
                                          So I decided to flash new firmware to SPI ROM. What do you say, would it help? If so, where can I find some dump? I was unable to find...
                                          02-04-2023, 03:11 AM
