LG 37 inch lcd tv with horizontal lines.
  • Acerman
    • Oct 2016
    • 30
    I have an LCD LG 37 inch tv with a fault. When powered on , initially the tv works completely normally with a good clear picture and sound. After approximately 10 minutes, 2 or 3 horizontal lines appear at the very top of the screen. Within a further 30 seconds more lines rapidly appear further down the screen. ALso the picture begins to freeze aswell. SOund remains normal. After a little more time the picture is becomes very distorted throughout the whole of the screen. If powered off, the problem remains. However, if unplugged for half an hour , the picture does return to normal, but only for 10 minutes when these problems start all over again. Anyone have any ideas. I am thinking maybe the t con.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: LG 37 inch lcd tv with horizontal lines.
    Guessing LC370WUE Panel ? Ive been able to fix one by replacing the ribbons from Tcon to Lcd but no luck with the others Ive had panel issue.
    • johns1mj
      • May 2015
      • 242
      You can use a hair drier to heat the t-con prior to turning on the tv. This will help diagnosis if the t-con is heating up and failing. You could also try cooling spray to cool the t-con after it acts up to see if it return to normal faster.
      • Acerman
        • Oct 2016
        • 30
        Thanks for the quick responses.
        Yes reeceyburger I thought it could be the panel. The screen does look like a faulty lcd panel after it has become distorted, but I am not sure as it works perfectly for a few minutes. Usually , if an lcd panel is faulty , the problem isn,t intermittent.
        I have some compressed air cans and will maybe try and spray it after the problem has started.
        I think there may be a heat related issue. The problem doesn't start until the tv has been on for 10 minutes and so has become warm.
        I read another thread and it suggested checking the ribbon cable from the tcon. I will get the back oof the tv tomorow and maybe check the ribbon cables and give them a clean with servisol.
        • Acerman
          • Oct 2016
          • 30
          Many thanks. Some good simple tricks to try.
          • Acerman
            • Oct 2016
            • 30
            The model is LG 37LH3000.
            • Acerman
              • Oct 2016
              • 30
              I removed the back cover and tcon cover this morning. I tried using a hair dryer to warm the tcon before switching on. The result of this is that the problem kicked in quicker. The lines started to appear after 5 minutes instead of 10. I also then cooled the tcon with compressed air spray. This restored the screen to normal but only for a few minutes afer which the lines started to appear again. I am thinking that the tcon is failing when it becomes warm.
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Maybe, what Tcon is it ? Possibly voltage reg falling out of spec when heated.
                • Acerman
                  • Oct 2016
                  • 30
                  The tcon model number is 6870c-0247A. It also works for a Sanyo model aswell as my 37 inch LG.
                  http://www.ebay.co.uk/itm/3219004638...%3AMEBIDX%3AIT
                  • Acerman
                    • Oct 2016
                    • 30
                    I bought a used tcon from ebay this week. I have fitted it this morning and all is well with the TV. The fault has gone. SO, it was a faulty Tcon. Thanks for all contributions. The test with the compressed air confirmed it.
                    • howardc64
                      by howardc64
                      07-24-2025, 05:17 PM
                    • Ihandyrepair
                      Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
                      by Ihandyrepair
                      Hi guys
                      I just started fixing 4k TV few months ago. so I am still learning a lot
                      I got this tv from friend complaint is ghosting or horizontal lines on image.
                      never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
                      then it started to show the ghosting white image.
                      I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
                      it has 3 thin small boards at the bottom of the...
                      12-05-2022, 04:18 PM
                    • rstrube
                      ViewSonic Pf815 (branded as P225f) Horizontal Deflection Issues - Running out of Ideas
                      by rstrube
                      Note: apologies I initially posted this request for help in the wrong forum! I am reposting it here and will take down the original posting.
                      Hi Everyone,
                      I've been working on repairing this beautiful CRT monitor off and on for the past several months and I'm really at a loss for what might be causing the problem.
                      Unlike other common Horizontal Deflection issues which result in a steady vertical line, when I turn the monitor on, there is a pulsing (somewhat segmented) vertical line. I've attached a photo that shows the issue (difficult to capture without video)....
                      11-23-2025, 01:37 PM
                    • rstrube
                      by rstrube
                      Hi Everyone,
                      Unlike other common Horizontal Deflection issues which result in a steady vertical line, when I turn the monitor on, there is a pulsing (somewhat segmented) vertical line. I've attached a photo that shows the issue (difficult to capture without video). The monitor itself is branded as a P225f, but it turns out that it's actually a Pf815 that has an Add-On smallish PCB that expands it to support...
                      11-23-2025, 12:19 PM
                    • noipi
                      samsung Oled 65 Horizontal Lines and Flicker
                      by noipi
                      I have samsung 65", i bought it last january 2025 2nd hand, and last month got this problem, flickering with horizontal lines. any inputs if this is Motherboard replacement or the LCD tcon, can someone help me what to do, i saw in YT, someone says that to cover the flex connector of the unit. Sorry for my english i am asian. i include the video so someone can help me out. thanks...
                      10-14-2025, 02:11 AM
