Vizio e320vl standby voltage 6.28v no 12v supply
  • danilodiaz9
    • Jan 2015
    • 17
    I have a Vizio e320vl lcd tv and I get an amber light but when you push power button it does nothing. My guess is power supply is good but main board is bad. I need some help with power on circuit. I do show 6.28v on standby but no 12v even when you press power button. Thank you in advance!
    Re: Vizio e320vl standby voltage 6.28v no 12v supply
    First, you better check the batteries of the meter.
    Second, we need the pictures of the whole backside of the TV showing all the board.
    • danilodiaz9
      • Jan 2015
      • 17
      Here are the pics
        Ok, so did you check batteries of the meter?
        We have to make sure the batteries are OK first, then we need to check the DCV of all the pins of the connector of the power supply board that goes to the main board to find out what are missing.
        • danilodiaz9
          • Jan 2015
          • 17
          I assume you are referring to batteries of my digital multi meter. I was going to replace but I realized I don't have another 9 volt handy. The voltage readings are
          Pin1 6.28v
          Pin2 6.28v
          Pin3 6.28v
          Pin4 0v
          Pin5 0v
          Pin6 0v
          Pin7 0v
          Pin8 0v
          Pin9 0v
          Pin10 0v
          Pin11 0v pson
          Pin12 0v 1--on/off
          Pin13 0v lamp
          Pin14 0v Dim
            by sam_sam_sam
            03-31-2024, 02:12 PM
          • fharris1977
            Vizio D50u-D1 Dead Set No Standby
            by fharris1977
            Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
            12-28-2023, 10:25 AM
          • Yanleb
            UN65MU6300FXZC, no standby LED but power supply good. Bad IC1604 25Q40?
            by Yanleb
            My UN65MU6300FXZC is dead and the standby LED stays off. The power supply is good. The main board is BN94-12434A.
            Disconnecting the main board from the power supply makes the backlight come ON.
            I did disconnect the panel cables and the WIFI modules, the board is still dead.
            I did read in many posts that IC1604 25Q40 becomes corrupted. It has proper 3.3 volt on VCC pin 8. I did read that if I post its dump here someone can fix it. Is that right?
            Thanks.
            11-18-2024, 12:34 AM
          • reessi
            JSK4228-050 Power Supply Standby voltage changing! (Possible from Wharfedale LTF37K1)
            by reessi
            I am trying to re-purpose this power supply that I saved years ago from a tv with a cracked screen for a monitor but that is not really that relevent at the moment. I do not recall which tv but a google search looks like it is from Wharfedale LTF37K1.
            You may notice I made some alterations moving some components to the top and some wires which are from a 5v regulator I fitted to the 12v output as the monitor requires 5v. The standby was already at fault from the beginning, it has nothing to do with the alterations...
            Years ago it had some bulging caps...
            04-26-2021, 11:42 AM
