LG 47LS4500 not powering on, has standby light
  • AcGeorgiegirl
    • Jun 2013
    • 202
    I'd posted(another posting) about this tv, but then everything changed, so I'm starting another thread, if that's ok. First, here's what was previously wrong:
    It was powering on, with sound and backlight- no picture, no menu shown, no matter what input was chosen. Sound worked on whatever input I tried.
    I tested the t-con's smd fuse, got 11.85 v on each lead. The P201 connecting power board to logic board has all 3 12-volts present, as well as all other voltages correct except the "Pwr-On", which I couldn't get a reading of(was at 0). I assumed one of the 12v pins supplied power to the t-con, going through the Logic board. I'd disconnected each of the panel ribbons, one at a time, and found that when the right ribbon was disconnected, I got half-screen of black with colored lines dispersed unevenly. When I disconnected the other side, the entire screen was glowing as before, when BOTH ribbons are connected.
    So...now this has all changed, and it no longer powers on. It does have a standby light(steady red). When I try turning it on, the standby light blinks 3 times slowly, stays off a couple of seconds, then goes back to steady red.
    Testing the P201 again, I find that no voltages are present except the 2 3.5v's.
    *I did cause a spark once, while testing the P201 the first go-round, and I'm worried I may have caused the set to now be shorted, or something, and not power up. The spark happened because I crossed more than one pin at the same time, I believe.
  • CapLeaker
    Leaking Member
    • 8146
    Re: LG 47LS4500 not powering on, has standby light
    Follow the 3.5V rail from the connector back on the PSU, though J96 back to the diode D201 and check it.
    • AcGeorgiegirl
      • Jun 2013
      • 202
      I'm not sure what you mean, sorry....are you saying to basically test the D201 diode?..or is there something else along the "way"?
      • AcGeorgiegirl
        • Jun 2013
        • 202
        D201 is reading 184 in diode mode.
        • CapLeaker
          Leaking Member
          • 8146
          test that diode both ways. Check fuse F501, D510, D502, ZD503, ZD501 D501 (primary of the STBY voltage rail). That 3.5V rail should be always on, as it is your STBY voltage rail. No STBY voltage and your TV is dead as a nit, since it feeds the main board.
          The secondary side of the 3.5V rail really only has a that diode, an inductor and a capacitor and a few jumpers. So if that diode is good, the problem has to be on the primary section. So then we make sure these diodes I mentioned are good, the fuse is good and IC501 is getting power. If you still didn't find anything bad, I'd be replacing IC501.
          Hope that it isn't too complicated to follow.
          • johnboy1313
            • Nov 2012
            • 1959
            https://www.badcaps.net/forum/showthread.php?t=44945
            • AcGeorgiegirl
              • Jun 2013
              • 202
              Thank you, CapLeaker...I think I've "got" what you are saying...helps to understand the primary/secondary thingy. I'm going to do a little reading so I understand better, then get started in the morning. I'll let you know!
              • AcGeorgiegirl
                • Jun 2013
                • 202
                Excellent "match", it seems, for my tv's issue. Thanks!
                • CapLeaker
                  Leaking Member
                  • 8146
                  Pretty easy. You just follow everything backwards on the board until you hit power. Just remember for voltage measurements on the primary side, the ground reference point of your DMM (negative lead) is the negative leg of the main filter capacitor (not chassis GND!). As for the ground reference point for the secondary, that is chassis GND or any GND point on the secondary side. Good luck!
                  • AcGeorgiegirl
                    • Jun 2013
                    • 202
                    All the diodes are good(all have OL on reverse polarity)
                    D501- 506
                    D502- 510
                    D510- 510
                    ZD503- 694
                    ZD501- 684
                    The F501 fuse is good, as well as the other 2 fuses on the primary.
                    • AcGeorgiegirl
                      • Jun 2013
                      • 202
                      Well, I went ahead and also tested the rest of the diodes on the primary side, and found that D607 is shorted. Kudos to JohnnyBoy13...after all! CapLeaker, what do you think...should I try other tests to make sure the IC is ok, or can that even be done? I've never attempted that before. I've just replaced ic's as you've indicated, when the diodes and fuses all are good.
                      • AcGeorgiegirl
                        • Jun 2013
                        • 202
                        My DMM was low battery, so I replaced it and retested everything. The D607 isn't shorted
                        ....so I'm back to replacing the IC, I suppose. Is there any testing to be done to make sure it's ONLY the IC? I've checked all of the board's diodes, fuses, and what I recognize as transistors.
                        • serious_electron
                          Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
                          by serious_electron
                          Hello Everyone!
                          I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
                          06-28-2025, 02:57 PM
                        • ChristianBr01
                          LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                          by ChristianBr01
                          I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                          The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                          What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                          04-23-2025, 01:48 AM
                        • AleMonti
                          LG 55EG910V - no power and no standby light
                          by AleMonti
                          I'm trying to troubleshoot and repair this old LG OLED curved TV, model 55EG910V.
                          I did some basic troubleshooting and reviewed most related posts here, but I wasn't able to isolate the issue.
                          The TV shut itself off during playback and never came back to life - the standby light remains off. My dad claims that it has happened a few times in the past but the issue resolved itself after some time. Not this one.
                          After checking the basics I did the following:
                          • I measured all voltages and as expected the only active supply is the 3.5V standby. It
                          11-04-2024, 05:02 PM
                        • Kaar3l
                          Samsung QLED QE65Q7FNAT only standby light
                          by Kaar3l
                          TV: Samsung QLED QE65Q7FNAT
                          PSU: BN4400940A
                          MB: BN94-12832K
                          I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                          09-24-2024, 01:35 PM
                        • jasonbay13
                          Philips 37HFL5682L/F7 no standby light, incomplete service manual?
                          by jasonbay13
                          picked up a tv and when the power is plugged, the standby light flashes real quick then goes off. of 3.3, 12, 24v is all there but i couldnt find any 5v on the back-end board. ON/OFF is low, which it seems is what turns on the backlight so i removed the wire at the back-end board and put a 10k resistor to the 3.3v, which when plugged in brings on the backlight for a split second and also a blue light "LED1" on the inverter board, which goes off after a short time.
                          am i missing something to bring on the backlight or is the inverter/ccfl gone bad? would that cause the inverter board...
                          12-01-2023, 09:55 PM
