ps4 hdmi problem
  • electronic-solutioncy
    Banned
    • Aug 2016
    • 19
    • 82496679322
    ps4 hdmi problem
    hello all i have a ps4 console that there is no display on tv i would like to know what is the voltage output for hdmi i thing all hdmi outputs are the same or i am wrong thanks
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Re: ps4 hdmi problem
    Think you need to replace the HDMI connector to get it working again. They fail for some reason. I think all hdmi connectors only have 5V.
      Banned
      • Aug 2016
      • 19
      • 82496679322
      5v to every pin
      • Moreno83
        • Jun 2014
        • 2008
        • The Netherlands
        No , only 1 pin.
        http://www.hdmi.org/installers/insidehdmicable.aspx
        • victor_cj
          • May 2015
          • 90
          It is very possible to have a hardware failure like MN86471A HDMI IC.
          The art of fighting without fighting
          • vinceroger69
            • Mar 2012
            • 6714
            • uk
            https://www.youtube.com/watch?v=-glW2Mv-XKs
            https://www.youtube.com/watch?v=8Gi6B-uatuc
            • groomit
              PS5 stuck at restore and than no power for some time
              by groomit
              Hi there,
              Tried to condense the problem in the title. Hope it was appealing for someone.
              I bought a broken PS5 with 2 sek. BLOD. When it arrived I noticed the bad condition of the console housing, bent cooler pipes and deformed disk drive. Yeah , obviously very bad drop damage. And obviously not appropriately described in the offer. Because it was my first hand on a PS5 for an okayish price, I decided to take the risk.
              It is an EDM-020 CFI-1116A.
              First thing I noticed was wrong initialization amperage. It went to 450 mA an then dropped to around 150 mA. Figured...
              01-22-2024, 04:01 PM
            • theone111
              by theone111
              3. Problem: TV shuts down
              07-22-2024, 10:36 AM
            • muhuruu
              PS5 too many USB devices connected
              by muhuruu
              Hello. I have a problem with a PS5 console that I bought to learn electronics repair. The auction description indicated that the console had been dropped. The HDMI port and USB ports were damaged. The HDMI port was replaced by the previous owner, and after his repair, the console worked for 2 days and then became dead. After receiving the console, I replaced all the USB ports. After replacing them, the console started to turn on. On the logo screen, it displays "too many USB devices connected". My further attempts to fix the error involved replacing the Southbridge, 4 TPS2001D chips,...
              05-19-2025, 07:14 AM
            • zombie.guitarist
              Reading Serial Midi data with an oscilloscope
              by zombie.guitarist
              Hey all, I have one last thing I'm looking to fix with my Synthaxe. This time, the schematics I have are actually the same as the PCBs I have.
              The Synthaxe, works as its a guitar midi controller hooked up to a floor pedal. Thats the most basic way of using it, and it has a midi output. You also can connect a console to it, that stores your tunings and other things. The console has 8 midi outs, as well as a midi in and midi thru.
              When I first got the unit, I thought I was using it wrong, but it turns out its just broken. The 8 midi ports on the console don't output...
              07-05-2023, 09:29 AM
            • supravit2000
              PS4 fat has inconsistent signal after HDMI replacement
              by supravit2000
              Hi, guys!
              I am not a professional, all I can do is solder stuff on the boards, so I would really appreciate it if someone with knowledge shares his experience/thoughts on a problem I have with a PS4 console.
              My friend gave me an original fat PS4, board model SAB-001, with WLOD, that has been previously opened. I changed the HDMI port, couple of pads on the board were ripped, which I connected to the corresponding caps/resistors? Just did so as in a shown diagram (one of the ground pads I ripped off and left it not connected). However, there was still no signal, so...
              12-19-2022, 08:08 PM
