Sony 40" lcd kdl-v40xbr1 wavy horiz...
  • RAMSELECTRONICS
    ATARI boy
    • Jul 2015
    • 48
    SONY 40" LCD KDL-V40XBR1
    The tv has wavy on the Horiz.. Please carefully to look the video the wavy is on the horiz when connected HDMI, Video in, etc... but not VGA (VGA run perfect)
    https://youtu.be/brodSAT0XNA
    I checked all caps looks great.
    HDMI 3 times changes also they are gold connectors.
    still no luck.. possible PSU?
    Help?
  • RAMSELECTRONICS
    ATARI boy
    • Jul 2015
    • 48
    Re: Sony 40" lcd kdl-v40xbr1 wavy horiz...
    No body replies?? umm interesting...
    • Logistics
      • Apr 2007
      • 721
      Have you tried moving the television to a different electrical outlet at your location?
      Are you plugged into a power-strip with other devices or the wall?
      Have you tried changing the power cable?
      • RAMSELECTRONICS
        ATARI boy
        • Jul 2015
        • 48
        Yeah Yeah 4 different located, no power strips.. but as long the VGA connected is perfectly. only HDMI and other Video inputs caused.
        I m guessing the HDMI board might be bad.
        • budwich
          • Jul 2015
          • 3097
          how about feeding a known test pattern signal into the set.... probably one showing full screen contrast / brightness level. It appears you have a ground issue. If you can get your hands on a input source that is not AC fed (eg. laptop or tablet) and see if that makes any difference.
          • RAMSELECTRONICS
            ATARI boy
            • Jul 2015
            • 48
            Oh yeah, I did tested with Laptop, DVD, BLU-RAY, Cable TV, Xbox etc.. all the same the issue..
            Any of HDMI, COMPONENT, VIDEO IN connectors got issue..
            Only VGA connector worked perfectly.
            So I use converting HDMI to VGA worked fine known as devices are good.
            I believe the HDMI board issue.. not sure where can we find the parts need to replace, I can do troubleshoot.
            I see all boards are connected the ground...
            • budwich
              • Jul 2015
              • 3097
              I haven't looked inside my set to see how it is wired but it is somewhat strange that the hdmi would be on the same board as the others you have noted as the hdmi is digital while the others have to be converted from analog. The vga (also analog) connector is a long way away from the "block of inputs" so perhaps it uses a different section.
              It still appears to be a grounding issue of the signal processing section.... check / clean all the board ground points / ensure boards mount screws are good / tight.
              You note a laptop test but was the laptop being powered from a wall connection?
              Further: quick look at the schematic, maybe the video switch on the "B card" is the issue. It appears that VGA signals (PC input) by pass that while others don't.
                HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
                This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
                09-12-2024, 02:00 PM
              • microso
                All in one Sony Vaio VPCL22Z1E 3D version no video on main display
                by microso
                I bought an all in one Sony Vaio VPCL22Z1E 3D version which does not show anything on the display, instead it works ok on the hdmi output (video and sound).
                I tested with a flashlight and it seems that it does not display the image without backlight.
                It doesn't make any sound in the built-in speakers and the headphone output has a very weak level.
                As an observation, I use a 19.5V power supply with 120W and in the specifications the original one would have 180W.
                Could this be the reason why it doesn't work properly?
                Mainboard is V021_MP_3D_1.1 1P-0115J00-8011...
                12-18-2023, 08:29 AM
                GeForce RTX2080 Super Aero video gaming card issues help need
                This is from my son’s gaming computer that at first had minor overheating issues when playing a very intense game with it causing the computer to crash or reboot
                Then bough a new motherboard and a new computer case that a cooling system in it already installed also brought the cooling system for this video card but now the issue with it is that it randomly rebooted screen goes blank randomly and suddenly video freezing or started with video being there then blank screen and then the video comes back or it just stays blank for a while and then maybe it will come back but it...
                05-07-2023, 08:12 AM
              • jason123
                Sony STR-DN1050 - No video, no BT, No WIFI, and FM is not changing stations
                by jason123
                Hello folks,
                New to Audio equipment - I got this receiver, I connected speakers and I tried to connect to Bluetooth. My phone would not see the receiver (Receiver flashes the BT as if it's trying to pair). Then I put it on FM radio, I get white noise on the speakers. I click the +/- Tuner button, and it moves from saved station 1 through 28, but the frequency is 87.x MHz not changing. At this point, thinking I may need to do a FW upgrade, I connected an HDMI cable to the TV and TV reports "No Signal" - TV "Kind of" sees the receiver (When connected to greyed out port,...
                05-27-2025, 07:26 AM
              • jrodefeld
                Sony GDM-FW900: Help me diagnose why it won't turn on? (Video included)
                by jrodefeld
                I have a vintage Sony GDM-FW900 crt monitor that I really enjoy using, but it has developed a problem and won't start up.
                This unit was completely serviced a few years ago by Unkle Vito in Los Angeles and it fully passed all tests, was factory calibrated, etc. There was a faulty part (can't remember exactly which one) that was replaced at another repair shop about a year ago. Other than that, it's been working great.
                I just say all that to say that this unit is probably in pretty good shape since it's been fully serviced and checked recently....
                03-03-2023, 09:51 PM
