LG 60PZ550: Sound, No Picture
  • SCCrepairstu
    • Sep 2016
    • 5
    I have come into a LG 60PZ550 and am trying to fix the problem. I have done the pattern test with no results and am needing further advice. Please advise as I am quite at a stand still.
    Thanks.
  • sordids999
    • May 2013
    • 2161
    Re: LG 60PZ550: Sound, No Picture
    Posting Clear pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
    • sordids999
      • May 2013
      • 2161
      Have you tested VA/VS/VSC voltage test points ?
      • SCCrepairstu
        • Sep 2016
        • 5
        Here is what I have done thus far.
        1)Co-worker said plasma had blue/pink spot in certain areas of screen.
        2)Confirmed screen issue
        3)Research lead me to the multiple threads about the cracked joints on the inductors.
        4) Pulled ZSUS and YSUS out and indeed had cracked joints.
        5)Resolder all cracked joints. Resoldered all joints that appeared dull, disturbed,cold, etc...
        6)Reinstalled boards, but TV would come on for a second then shut off. I could hear the relay switching on and off on the supply board.
        7)Tried TV with only ZSUS board connected. TV came on but no picture. Measured voltages off supply board to ZSUS. Nominal.
        8)Tried TV with YSUS board. TV would come on then shut off.
        9)Measured voltage to YSUS from supply board with YSUS board removed. Nominal.
        10)Used both DMM and Scope to see if I could observe a transient voltage off the supply board with the YSUS board connected. None.
        11) Suspected YSUS has shorts. Found several IGBJTs with shorted leads.
        12)TV was time sensitive to owner, so he opted to buy new YSUS board.
        13)Installed new YSUS board and TV now comes on and stays on. Sound is present, but no picture.
        • SCCrepairstu
          • Sep 2016
          • 5
          Disregard previous message. VSC and VY are not nominal as seen below.
          Ok so I have measured the voltages and here is what I got
          VS 199V
          VA 53V
          VSC 1KV+
          VY 1KV+
          VZB 108V
          • sordids999
            • May 2013
            • 2161
            VS 199V
            VA 53V
            VSC 1KV+
            VY 1KV+
            VZB 108V
            VSC is low are you sure the replacement Ysus you purchased was ok ?
            • sordids999
              • May 2013
              • 2161
              have you also tested the buffer board for shorts ?
              • syaoran123
                • Jun 2014
                • 178
                Does the control board have a green blinking led when turned on?
                • TR103
                  by TR103
                  - it keeps rebooting
                  01-22-2025, 04:12 PM
                • Mgiffune
                  by Mgiffune
                  06-09-2024, 10:28 AM
                • Ierwin
                  by Ierwin
                  05-13-2025, 03:31 PM
                • jchang
                  Samsung UN70NU6900F no picture and no sound
                  by jchang
                  Hi all
                  I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                  Symptom:
                  No picture no sound.
                  When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                  No sound at all.
                  What I tried:
                  1. I tried unplugging the left or right ribbon...
                  01-09-2023, 06:28 PM
                • ChaosLegionnaire
                  by ChaosLegionnaire
                  09-13-2022, 09:02 AM
