Pioneer 1150HD powering on issues...
  • valthonis
    • Sep 2016
    • 4
    • US
    So my Pioneer 1150HD has recently started having fits.
    If I plug it in and press the standby button in the lower left the red light comes on to indicate standby. Pushing neither the remotes power button or the TV's power button (on the right side next to the channel and volume buttons) will do anything.
    However, eventually (within a couple minutes) the TV will turn itself on. It takes a little bit for the unit to boot up but then displays a "Powering Up, please wait" display. If I go into the home menu the Tuner option is grayed out. Note the TV does respond to the remote during this time.
    After another minute or so of messing with buttons or leaving it alone it will turn off with the 12 blinking blue light pattern.
    I have tried doing a reset via the remote, but since it doesn't respond to the power button on the TV or remote I cannot seem to get it to do the reset.
    My initial thought and research is the 12 blinking lights is related to the TV guide information and I want to reset it so I can set the guide to 00000 to disable it, but without being able to get into the reset option I cannot do that.
    Thank you in advance for any thoughts or advice.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Pioneer 1150HD powering on issues...
    Images of the boards please ?
    • valthonis
      • Sep 2016
      • 4
      • US
      I have not disassembled the rear of the TV yet, figured I would inquire before doing that. I will work on disassembling it today.
      Before I disassemble it, should I remove it from the stand and lie it flat?
      • valthonis
        • Sep 2016
        • 4
        • US
        Weird, I cannot explain why it happened, but I unplugged it over night and after plugging it back in it works fine this morning. I disabled the TV guide information just in case (setting the zip to 00000s).
        • tmhobadcap
          Pioneer VSX-522-K remote control not working???
          by tmhobadcap
          I have this receiver for at least 10 years. Usually, we just use the remote for turning on/off and adjusting the volume. Recently, the remote control started not able to turn the receiver on. Later, the volume also could not be adjusted by the remote control.
          At first, I thought that it was the usual problem which can be fixed by cleaning the contacts on the switches and the pcb. I opened the remote and clean it with alcohol. The remote did work again after that. But after one day, it did not work again. I opened it again and clean with alcohol and contact cleaner. Again it worked...
          12-24-2020, 01:44 AM
        • janos666
          Pioneer LX5090 - 2x Red blink after auto-shutdown
          by janos666
          I was trying to reset the Pulse Meter and re-adjust the Panel-1/2 settings in the SM on an exceptionally old Pioneer LX5090 (51k power-on hours according to it's SM). I did this many times on much less aged specimens (with 10-20k hours) without issues. After following the usual workflow, I noticed the darkest gray shade showed up black with bright sparkles. I tried to adjust some other parameters but it didn't disappear. Then I went on and restored the old values of the parameters I don't usually touch (although I did this from memory, so I might have made an error). After that, I started going...
          03-26-2023, 11:20 AM
        • Servicem4
          Pioneer lx 701 hdmi issues
          by Servicem4
          My receiver pioneer LX 701 doesn't work anymore correctly The history:
          6 month ago hdmi picture output didnt work anymore but music input through hdmi still worked.
          Since some weeks even this doesn't work. Right Before this occured i heard a plopping noise from the receiver one evening.
          The rest of the receiver works, I used spdif for sound input.
          I now opened the receiver and hoped to find a blown fuse but all look good.
          Any tips how to progress? Between 2 PCB there is something which looks like a blown cap....
          Image 20250527-204839 hosted in ImgBB
          05-27-2025, 01:13 PM
        • cstout
          DeLonghi AC Remote only accepts 3V
          by cstout
          Hello all, I've been looking into this portable air conditioner's remote control and can't find what could be causing the problem - or possibly this remote is just terribly designed.
          The remote only works at exactly 3V - if I drop it any lower, using my bench power supply, to say, 2.9V then the remote will not flash the display and turn off. I don't have any AAA batteries that are exactly 1.5V each so I'm not sure if this remote is designed this way - to only use the freshest possible batteries, or if there's a failed component in the mix.
          I can't find any schematics...
          06-03-2024, 03:53 PM
        • Mc_Millian
          Toshiba 50lf711u20 fire tv remote not pairing
          by Mc_Millian
          I was wondering if anyone could help my in pairing a remote with a Toshiba fire tv?
          The Tv model number is: 50lf711u20 Rev B.
          I've already replaced all the the circuit boards within the tv along with the I.R. sensor receiver.
          I've tried 3 different remotes which should be fully compatible with this TV.
          Oddly enough. A few if the buttons on all of the remotes actually work. Even without pairing...which makes no sense.
          The power button, along with the volume,back,select, and directional...
          04-07-2022, 12:15 PM
