PS-42Q97HD, not starting every time :( HELP !!!!
  • jczarniak
    • Oct 2015
    • 179
    After switching OFF and ON from the power socket (sometimes a few times) TV is starting fine.
    Checked a few voltages:
    When TV struggle to switch on I've got:
    instead of 18V - 11.3V
    instead of 12V - 11.4V
    Va=33.5V
    After switching OFF and ON from the power socket (sometimes a few times) TV is starting fine and:
    18V test point - 18.5V
    12V - 12.4
    Va - 63.5V etc...
    TV works fine, stays on as long I want.
    Help, please.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: PS-42Q97HD, not starting every time HELP !!!!
    Have you checked for cold solder joints ?
    • sordids999
      • May 2013
      • 2161
      +1 mate
      • jczarniak
        • Oct 2015
        • 179
        Yes I did, didn't found anything.
        When TV is ON stays on forever
        Unplugging its power cord and plugging it back in, its the only solution which I found so far.
        Need to do it sometime a few times.
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          A repair kit has the following components so you could check the following parts out.
          F801S
          FS801S
          QS801
          QS802
          DS803
          DS804
          RS812
          RS814
          ICS801
          • jczarniak
            • Oct 2015
            • 179
            F801S
            FS801S
            QS801
            QS802
            DS803
            DS804
            RS812
            RS814
            ICS801
            All them parts looks OK.
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Hmm this model Psu is known for bad caps, have you an esr meter ? If not does heating the Psu with a hairdryer help it come on faster ?
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                F801S
                FS801S
                QS801
                QS802
                DS803
                DS804
                RS812
                RS814
                ICS801
                Lol DB re-read the thread it does come on after a sec.
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  I realise it's the parts list for a faulty psu but considered it may be worthwhile checking the components.
                  Have the resistors changed value, check the components/solder joints around the IC for example.
                  It was just a thought although as you say it is often capacitors that cause this problem.
                  • sordids999
                    • May 2013
                    • 2161
                    have u actually reflowed any joints or just looked for cold solder joints ?
                    • jczarniak
                      • Oct 2015
                      • 179
                      All suspected (and not also) joints has been re flowed.
                      A few new observations:
                      when TV is cold (has been switched off for 10 hrs) is switching ON straight away, works fine, stays ON etc...
                      When switched OFF after about 15 minutes of work, blue light which should be ON all the time (setup in menu) is like dimmed and comes back on after 10-15 minutes.
                      No chance to switch the TV ON, need to wait for good 10-15 minutes.
                      • flocko
                        • Nov 2012
                        • 1121
                        Please make yourself clear, when you say the set is off do you mean unplugged from wall socket, or in standby.Replaceing the small caps (50v) on hot side of the supply would be a good place to start from
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          You need to isolate the Psu first, heat it and follow what I said.
                          • jczarniak
                            • Oct 2015
                            • 179
                            Just found the burn mark under zener diode ZDB803 (already removed on the picture)
                            Could it be a reason of all my problems with that power supply?
                            Can't find replacement anywhere - MTZJ30C
                            Can I use any equivalent, please?
                            Thank you.
                            • dick_barton
                              • Aug 2015
                              • 6643
                              • Wales
                              Zener Diodes Zener 500mW 2,5% 30V
                              Data sheet available from:
                              http://eu.mouser.com/ProductDetail/T...8wxQLQMw%3d%3d
                              CPC, RS or Farnell will probably supply them or its equivalent.
                              • jczarniak
                                • Oct 2015
                                • 179
                                Thanks a lot.
                                What you thing about this one, please:
                                http://uk.rs-online.com/web/p/zener-diodes/0812572/
                                Thank you.
                                • dick_barton
                                  • Aug 2015
                                  • 6643
                                  • Wales
                                  The tolerance is twice the value but same working voltage and higher power dissipation so worth a try. May be worth your while checking around that circuit to see if anything else has failed and caused the zener to overheat.
                                  Have you got a Maplins near you?
                                  • jczarniak
                                    • Oct 2015
                                    • 179
                                    Yes, 5 minutes drive
                                    • jczarniak
                                      • Oct 2015
                                      • 179
                                      Something like that?
                                      http://www.maplin.co.uk/p/bzx85c-30v...er-diode-qf64u
                                      • sordids999
                                        • May 2013
                                        • 2161
                                        Have u tested the diode ?
                                        and i would certainly do what flocko said start testing the caps etc
                                        • Lcd22
                                          Lenovo s145-15api work fine after bios flash for some time, like a few restarts or power cycles.
                                          by Lcd22
                                          Hi! I have a Lenovo s145-15api Ryzen 5 3500u, he need a bios reflash, i made that (tried with ch341a and ezp2023+). I tried a lot of dumps, and all do the same, so i think is a hardware problem. So after reflash, laptop work fine a short time, after some restart or power on/off, the laptop have again same symptoms, need a new bios. Do it again and again and same result. What are u think is the problem?
                                          08-28-2024, 10:38 AM
                                        • titomno2
                                          Gaming Laptop Zephyrus S17 TFT not detected every time !
                                          by titomno2
                                          Hi guys,
                                          I post my problem here because I think it could be a capacitor related issue (Asus support on this particular subject is non-existing).
                                          So the computer is a Zephyrus-S17-GX735LXS-26T and the strange behavior is seen.
                                          On cold start most of the time the internal screen is detected and a picture it works fine until shutdown, sleep or deep sleep.
                                          Then the screen won't work for a long period of time.
                                          If I wait 1 or 2 hours it work again most of the time.
                                          When it doesn't work the batterie indicator blink 3 times white stop and the same schematic is repeated...
                                          01-19-2025, 08:27 AM
                                        • smic717394
                                          Macbook Pro 8.2 2015 kernel task 100% and very very slow
                                          by smic717394
                                          I need a bit of help. I have a Macbook pro end 2011 8.2. I bought it of a customer cheap because it has a bulged battery. I replaced the battery and upgraded the ram 2x8GB total 16GB, and replaced the HDD with a SSD. What happens with this laptop is very strange and I don't know where to begin. The laptop doesn't panic, tha fans run normal even when the kernel is 100%. If I reset the SMS, will run normal for about 30 to 1 hour then the kernel_task goes to 95% and the laptop become unusable. If I reset the sms agail will run again normally for some time. I thought is the battery,...
                                          12-14-2024, 01:32 PM
                                        • CG2
                                          Meaco Arete One / Deye Dehumidifier not working
                                          by CG2
                                          I've got a dehumidifier that has stopped working. Plug it in, press the power switch, and it beeps 5 times. Nothing showing in the display (which is just two 7 segment displays) apart from the two decimal points flashing. The model is a MeacoDry Arete One 18L, which seems to be a rebadged Deye (all the boards are marked Deye). Here's what I've got so far (details in case anyone else in future should need them).
                                          Starting with the power board. Mains power comes in at the red connector top left. The compressor is powered by the orange connector to the right of that and is switched by...
                                          08-17-2024, 07:47 AM
                                        • angeloavv
                                          ASRock H81M-DG4 power cycles and glitches - sometimes POSTs sometimes not
                                          by angeloavv
                                          Hello everyone! This is my first post and this motherboard is driving me crazy because everything looks so non-trivial that I don't know where to start investigating. During these days I believe I watched half of the YouTube videos trying to understand how to troubleshoot power cycles but at the same time, I'm confused because my motherboard doesn't always do that and sometimes completes the POST for a few seconds: the right amount of time to freeze, show glitches on the screen, and then reset itself.
                                          Let me give you a bit more context to understand why and how we got here.
                                          12-26-2023, 03:32 PM
