tc-P50U50 power on, all white screen
  • xxsuperstreetxx
    • Jun 2015
    • 8
    • usa
    I have a panasonic plasma. It powers on and has an all white screen. When i change inputs with the remote is goes a tiny bit less white on one of them but bright none the less. No menus are present. i have tried to reset the tv. The SS board has been previously repaired. There are no blink code errors.
    Any idea what is wrong?
    I checked all screws to look for any loose ones, and reseated all cables.
    Thanks!
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Re: tc-P50U50 power on, all white screen
    Do you have sound.
    Does it respond to the remote control.
    Do you have sharp pictures of the circuit boards.
    Have you run the Test Pattern test?
    • xxsuperstreetxx
      • Jun 2015
      • 8
      • usa
      i have sound.
      it responds to the remote control.
      the pattern test does not show up (and i tried to factory reset from the service technician mode), however i am doing it blindly as there are no menus.
      I have attached pictures, but nothing jumps out at me. I can see that the SS board has had the upper resistors replaced that are attached to the upper heat sink (visible from underside and a very common problem on this set). Nothing else looks bad.
      Thanks for all of your help! this is the first time i have come across this all white screen issue!
      http://postimg.org/gallery/qm7jkpl2/
      • dick_barton
        • Aug 2015
        • 6642
        • Wales
        At this point I think it would be worth checking all your voltages are present on the PSU.
        • dj01fad
          • Sep 2014
          • 92
          • romania
          Bad A board I guess... if it was from the P board, it would go into an error.
          • xxsuperstreetxx
            • Jun 2015
            • 8
            • usa
            i should also add that as soon as the tv is powered on, it shows a black powered on screen for half a second, then resumes to the solid white screen.
            • harp
              White screen repairs
              by harp
              To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
              Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
              On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
              05-13-2024, 03:43 AM
            • Ryan.man
              by Ryan.man
              02-04-2025, 12:23 PM
            • EazyBone
              Sharp LC-65Q620U White Screen
              by EazyBone
              Another TV topic!!
              I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
              The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
              Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?...
              08-21-2024, 12:56 PM
            • hcinne
              Dell G15 ryzen edition black screen 2 amber 1 white
              by hcinne
              I have a Dell G15 ryzen edition (ryzen 5) that turns on but won't post, black screen, keyboard lights on, caps lock led on, fans turns and the battery indicating light is showing 2amber and 1 white according to dell website it's a cpu failure, but i tried few basic things before i open it up i tested the screen by pressing the d button before powering it up but it didn't show anything i tried the ctrl+esc for bios recovery but still black screen i tried refreshing the screen, i plugged it on an external monitor but same thing. Next step i unplugged the battery and kept pressing the...
              07-23-2024, 07:56 AM
            • Chrissygizmo
              Panasonic TX-48CX350B backlights but white screen , blank screen
              by Chrissygizmo
              Hi all, I’ve got a problem I hope someone can help me fixi.
              I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
              01-11-2025, 03:18 PM
