LG 32le5300 with bad power supply (help)
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8327
    Re: LG 32le5300 with bad power supply (help)
    Huh? Why doing that when you don't have any short there?
    • Dannyx
      CertifiedAxhole
      • Aug 2016
      • 3912
      No worries - I wasn't gonna do that anyway, since I quickly remembered that upon shunting the relay, the bulb stayed off, so the caps were fine (unless they start experiencing breakdown under high voltage, which is just as unlikely).
      Wattevah...
        I am not really looking for shorted cap but shorted Load, and I still suspect something in the PFC IC, when you jump the relay but not applying the force on then there will be no VCC to feed the PFC IC so there will no bias Voltage to fed the GATE of the MOSFETS..
        We still need to resistance betwen the VCC and the Gate drive of the IC.
        • Dannyx
          CertifiedAxhole
          • Aug 2016
          • 3912
          I'll do that on Monday, since the board is at work and I don't work on Sundays
          Wattevah...
          • Dannyx
            CertifiedAxhole
            • Aug 2016
            • 3912
            Just measured the resistance between VCC and GD: it's 5.3kOhms in both directions (that is, no matter how I connect my + - probes).
            Wattevah...
            • Dannyx
              CertifiedAxhole
              • Aug 2016
              • 3912
              #26
              Bad news: replaced the PFC IC and the check lamp STILL stays on.....where the heck could this short be ? I've stripped down almost EVERYTHING ! The only thing left is the PFC coil....
              Wattevah...
                I wonder if you change the 40W lamp to 100W lamp to see if it will still light up brightly or not. Did you use 40W lamp on other 32" TV before with just the power supply board by itself forced on but without loads connected?
                • Dannyx
                  CertifiedAxhole
                  • Aug 2016
                  • 3912
                  #28
                  A 100w bulb obviously won't be AS bright, just because it requires more amps to flow through it, which in turn would make it more dangerous to the circuit. I've already packed up the TV and returned it as it was sadly, since the guy didn't want to wait any longer, so the only thing we can do at this point is speculate what could've been wrong with it. I've always used the 40W bulb, as it seems to be just the right value: neither too high nor too low. A 25w one would glow dimly even when the circuit is fine, while a 100w one might not come on even when a fault is present, plus it would allow more current to flow due to its lower resistance, possibly destroying something on the faulty circuit under test. Bottom line: 40w FTW ....too bad they're disappearing and hard to come by, with everything turning "eco, green" and shitty. Try that with a CFL....>_>
                  Wattevah...
                  • Dannyx
                    CertifiedAxhole
                    • Aug 2016
                    • 3912
                    #29
                    Also, the answer to your last question is YES (have used it on just the boards - I never use the lamp on a fully assembled TV). I felt like I didn't really answer it in my long post
                    Wattevah...
                    • CapLeaker
                      Leaking Member
                      • Dec 2014
                      • 8327
                      I use a 100W bulb nothing else.
                        That is what I use also when testing just the board and no load.
                        • Dannyx
                          CertifiedAxhole
                          • Aug 2016
                          • 3912
                          #32
                          Could also be because you're on an 120V line and you can use a lower series resistance to compensate....just a thought.
                          Wattevah...
                          • addltd
                            • Jan 2017
                            Budm,
                            Did you get to a resolution on your powersupply fix for the LG 32LE5300? I have exactly the same CAP and fuse blown, but I don't want to start down the replace everything path. Did just the cap and fuse do the trick? Thanks!
                            • Dannyx
                              CertifiedAxhole
                              • Aug 2016
                              • 3912
                              #34
                              Originally posted by addltd
                              Budm,
                              I eventually gave up on this one, but you might get away with applying power straight to the primary side with no PFC (that is, from the bride rectifier, you go straight to the reservoir caps and see if it turns on).
                              Wattevah...
                              • addltd
                                • Jan 2017
                                Thank you!
                                • Babbar
                                  by Babbar
                                  04-12-2024, 01:12 AM
                                • Tynan Dill
                                  by Tynan Dill
                                  Assuming...
                                  11-22-2024, 01:46 PM
                                  03-31-2024, 02:12 PM
                                • beetle1303
                                  Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
                                  by beetle1303
                                  I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
                                  On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
                                  01-13-2025, 08:49 PM
                                • jesterace
                                  Samsung UE46ES8000 Blown fuse but no other signs of short
                                  by jesterace
                                  Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                                  09-11-2024, 03:14 PM
