Panasonic TX-P37X20B service mode
  • delphiplasma
    • Mar 2016
    • 23
    I was just wondering if there was a setting in the service mode to enable numerical values to the brightness, volume ...etc controls?
    Thanks in advance
    LCD LED TV Service Menu Codes
    TCL LED TV Service Menu Code
    LG LED TV Service Menu Code
    10-31-2024, 03:58 AM
  • AustinCER
    Dell XPS 8940 | Manufacturing Mode? | No Service Tag
    by AustinCER
    Hello, I currently have a Dell XPS 8940 in our office for repair.
    Service Tag: HG1Y673
    The most recent BIOS is pictured below -- being available as an .exe on Dell website.
    Needed a new motherboard due to power surge. The motherboard replacement was installed and upon power up it was booting to a display message - Manufacturing Mode Active -
    Have not dealt with this issue before or what the proper steps are. I booted to the BIOS and manually entered the Service Tag, but upon each reboot -- the service tag is wiped and shows the Manufacturing Mode display message,...
    07-15-2025, 05:28 PM
  • RRice25541
    Sharp Lc-50UB30U may be locked out of Service Mode and Factory Mode
    by RRice25541
    So i got this tv from my neighbor, when it wasn't working right for him,, he purchased another tv and gave his old to me.
    the color is all outa wack, like the settings have been corupted,
    I've already done a firmware search using the wifi connection update from the tv and it didn't find any new update so it's got the most recent version.
    so
    The issue is i can't get into service mode or factory mode, tried resetiing it from user mode and it didn't change anything.
    when i bring up the menu and type the pass codes to access either mode the menu disappears...
    05-13-2022, 10:44 PM
  • LittleMega
    CRT Panasonic TV model TX-25T2L Service Mode (?)
    by LittleMega
    Hi guys,
    I have opened the same Thread on AV Forum and they suggested asking here as I didn't sort the following issue:
    I am trying to enter in the Service Mode of a CRT Panasonic Colour TV model TX-25T2L, serial no. LE-331011 (Alpha 2 Chassis) manufactured in UK.
    I tried the most common procedures for CRT Panasonic which match with the operations available on the remote control:
    set the Bass to maximum position,
    set the Treble to minimum position,
    press Vol – on the customer controls at the front of the TV, and at the same time press
    11-24-2022, 08:58 AM
  • thesame
    JVC LT-40V750 stuck in service mode switching colors.
    by thesame
    The tv is stuck in service mode, i have unpluged it for several times, tryed to power it separate from remote , tryed some reset method using menu button and 4725 typed twice in a row to enter or disable the service mode but it didn't work. The board has no damaged components, could it need a fresh firmware or the emmc could be dead?...
    01-12-2024, 10:39 AM
