Y-SUS/BUFFER board for LG 50PN450B, burned caps
  • jczarniak
    • Oct 2015
    • 179
    I've got LG 50PN450B with faulty Y-SUS/BUFFER board.
    Board no: EBR74825301 / EAX64561401
    All I can see are two burned caps: C415, C416.
    Anyone knows, why they gone, what else could be faulty etc ... ?
    Can't find any obvious short circuit etc ...
    Thank you for any support.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Y-SUS/BUFFER board for LG 50PN450B, burned caps
    Check the forum for this Tv/board common issue I belive is just them caps failing.
    • jczarniak
      • Oct 2015
      • 179
      Checked the forum, thank you.
      There is no picture or glow at all (black screen) just because of them two caps?
      Is there any way to bypass etc... to prove, check the board because I don't know the values of the caps.
      Thank you.
      • Hamie
        • Apr 2014
        • 1383
        The caps are 22nf
        • jczarniak
          • Oct 2015
          • 179
          Originally posted by Hamie
          The caps are 22nf
          Thanks a lot.
          Will be this one good enough, please?
          http://uk.rs-online.com/web/p/products/2644602/
          Do I need to replace anything else or just them 2 caps?
          Thank you.
          • jczarniak
            • Oct 2015
            • 179
            I also found shorted Q401 and Q402, GT30F133
            Anyone knows any equivalent / replacement which I can buy in RS Components, please?
            • howardc64
              by howardc64
              Problem
              08-04-2024, 10:36 PM
            • m1ch43lzm
              by m1ch43lzm
              05-12-2025, 08:37 PM
            • Dani_2024
              by Dani_2024
              10-28-2024, 05:06 PM
            • black6host
              Replacement caps for Samson Resolv studio monitor 65A Amp board.
              by black6host
              Good day!
              I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
              I'm going to replace the caps and I'll be the first...
              02-06-2024, 08:22 PM
