Unable to clone nand-flash
  • Pragmatiko
    • Jul 2013
    • 468
    • IT
    Hello guys,
    I am going crazy for to clone nand flash MT29F8G08ABABA WP of Philips TV.
    With programmer i read original flash but if i copy dump on new flash the tv wont turn on.
    With original flash tv work.
    Can someone explain me why?
    Thank you.
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Unable to clone nand-flash
    Originally posted by Pragmatiko
    Hello guys,
    Thank you.
    When you read the original you saved it as a dump file. Can you compare a read of the cloned nand flash to the dump to verify.
    • Pragmatiko
      • Jul 2013
      • 468
      • IT
      Well, when i do a verify i see that some bytes also if same value are allocated in different address.
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        If that's the case then it hasn't made a true copy and the clone would be invalid.
        • Pragmatiko
          • Jul 2013
          • 468
          • IT
          Which would be the solution for to get perfect clone?
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            Unfortunately I'm unfamiliar with the IC. All I can suggest is try and google as much information as possible and double check you programmer settings.
            • ecking767
              • Oct 2009
              • 492
              which NAND programmer you have?
              • Pragmatiko
                • Jul 2013
                • 468
                • IT
                SmartPro 5000U Plus
                • victor_cj
                  • May 2015
                  • 90
                  • Romania
                  Maybe this programmer cannot clone or repair bad memory blocks from MT29F8G08ABABA, he just ignore them.
                  The art of fighting without fighting
                  • ecking767
                    • Oct 2009
                    • 492
                    have you program any other NAND chip with this programmer?
                    the reason I ask, sometime the software for the programmer isn't correct for NAND memory chip.
                    I had a Wellon VP896 and Its never read or write to the NAND memory chip I was trying to read/write too. Tech support at wellon claim their programmer can read/write to NAND chip. I never got a successful read.
                    when reading a NAND memory the software shouldn't read bad blocks, if there is an option in the configuration setting about reading bad blocks you shouldn't read bad blocks.
                    when writing bad block should be skip, the programmer software should control this function
                    • Pragmatiko
                      • Jul 2013
                      • 468
                      • IT
                      I will try to contact programmer.support for to ask the correct programmmer configuration for to have a perfect clone.
                      Yes i have already cloned some.others nand and ever worked.
                      • Pragmatiko
                        • Jul 2013
                        • 468
                        • IT
                        Solved, need to put right programmer configuration
                        • ecking767
                          • Oct 2009
                          • 492
                          also I notice that some NAND memory chip has no bad blocks or very little. does your software tell you how many bad blocks the chip have if you erase the chip.
                          Most Micron NAND memory I have read has no or very little bad blocks.
                          I have the TNM5000 and its works great!! no problem reading or writing to any NAND memory chip !!!
                          the software is well layout with good features.
                          • Pragmatiko
                            • Jul 2013
                            • 468
                            • IT
                            • ecking767
                              • Oct 2009
                              • 492
                              yes you don't want to read bad block with copying NAND memory. doesn't the software inform your how many bad block is there when you erase or do a blank check?
                              • Pragmatiko
                                • Jul 2013
                                • 468
                                • IT
                                i will check
                                • redelectron
                                  • Sep 2016
                                  • india
                                  I am facing the same problem with this device on ChipProg 481.
                                  Can you please help?
                                  • Pragmatiko
                                    • Jul 2013
                                    • 468
                                    • IT
                                    You need to ask right config device to support of you programmer.
                                    • cosander
                                      • Mar 2018
                                      Hey Prag can you share the config you used? I am trying to clone MT29F2G16ABAEAWP and the chip will never verify. it has the wrong data in the wrong address
                                      • Deeloc
                                        How to flash SSD 1tb WALRAM controller SM2259XT2G flash samsung NAND V6
                                        by Deeloc
                                        I have a 1tb WALRAM SSD (Photo)
                                        Controller SM2259XT2G (photo)
                                        Samsung memory (photo):
                                        Part Number K9DVGB8J1B DCK0
                                        Name V-NAND V6
                                        Type TLC
                                        The SSD itself is detected as 1gb, but is not initialized.
                                        There is a Sata to USB adapter
                                        A lot of SMI MPTool, did not flash it. compare flash fail (17)
                                        K9DVGB8J1B is not listed anywhere
                                        What to flash?​...
                                        06-05-2024, 08:32 AM
                                      • DoOm86
                                        Swap nand flash smartphone for data recovery
                                        by DoOm86
                                        Hello everyone.
                                        I would like to know more about the following topic:
                                        Nand flash on smartphone for data recovery.
                                        I have been reading of people swapping nand flash from a faulty mainboard to another in order to save the data.
                                        But I also read about encrypted data which to be read must been swap also cpu, or nfc or something else where is located the key to make the data being readable.
                                        How does it works? How do I know if data are encrypted or where is the key?
                                        I know there are also very expensive external socket where you can put the nand flash in...
                                        08-20-2023, 07:10 AM
                                      • ekozeko333
                                        [Help] Lenovo Yoga Slim 7-14ARE05 (DA0LS3MBAF0) – 25Q80DVN1G Flash Is All FF, USB-C PD Stuck at 5V
                                        by ekozeko333
                                        I’m trying to recover a Lenovo Yoga Slim 7-14ARE05 with board DA0LS3MBAF0 Rev:F. I’ve run into an unusual issue where USB-C PD is stuck at 4.7–5V and the system won’t boot (keyboard lights flash briefly, then nothing).
                                        🔥 The Problem Started After Suspected ESD/PD Fault
                                        I experienced a power issue or ESD event through a USB-C charger
                                        After that, the NX20P5090 power switch was visibly burned and was replaced
                                        Now the PD controller always negotiates 5V @ 2A, even with known-good chargers
                                        🧠 What I’ve Done So Far
                                        Flashed...
                                        06-21-2025, 02:48 AM
                                      • corrize
                                        Nikon D800 camera - flash don’t work and capacitor don’t charge
                                        by corrize
                                        Hello, I'm stuck in troubleshooting…
                                        The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
                                        In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
                                        When I press the flash button, it's detected by the system, flash icon appear on LDC display....
                                        10-01-2022, 10:02 AM
                                      • testaccgta
                                        Unable to verify IC or write/erase/flash BIOS file to XMC QH128AHIG SPI chip using NeoProgrammer/AsProgrammer
                                        by testaccgta
                                        Hi, everyone!
                                        I've recently acquired two brand new SPI chips to replace the one currently in my Acer A514-54G laptop MB (FH5AT LA-K092P). The reason why I'm replacing the current SPI chip is because I had some difficulties with a third-party IT assistant who pretty much lacked the soldering skills and ended up destroying the current SPI chip soldered to my MB from factory.
                                        I've decided to do this on my own because I spent the past month or so learning some soldering skills and BIOS modding through Badcaps and WinRaid forums, hence the attempt. I've also chosen to buy...
                                        09-01-2024, 08:24 PM
