Samsung PN50A450P1D vertical lines
  • Larz2112
    • Aug 2016
    • 7
    I have a Samsung PN50A450P1D 50" plasma TV. I've had it about 7 years with no problems. A couple of days ago about 5 columns of vertical RGB lines and a black vertical bar about 1.5" wide showed up on the screen about 12" from the right edge of the screen. From what I have read it might be a bad logic board, bad main board, loose connectors, or a bad screen. I'm willing to open it up and check connectors, replace a board, etc. if there is a decent chance that it will fix the problem. But I'd rather not go through the trouble if it's most likely a bad screen.
    Based on the type of lines (see photos), what are the chances that it's a bad screen versus something that might be fixable?
  • mulox
    • Jan 2017
    • 4
    Re: Samsung PN50A450P1D vertical lines
    I have a similar situation with mine, but your lines are bit more pronounced.
    Just sad that you did not get any responses yet...
    • rccrasher65
      • Mar 2014
      • 626
      Bad plasma display.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Bad pdp.
        • Stanley1843
          by Stanley1843
          06-29-2024, 11:54 AM
        • Falki
          Colorful LCD Vertical Lines on Samsung ue55es8090
          by Falki
          Hello there, ive recently found an older 55inch Samsung SmartTV.
          A similar issue has been posted as well but also with no actual response ...
          08-12-2025, 04:19 AM
        • Kambi13
          Samsung LE32C530F1W with vertical lines on Screen
          by Kambi13
          Hello all, I'm dealing with a Samsung LE32C530F1W that now has vertical lines on the right side. It started with a ghost image on the top of the screen and then I tried the old trick of masking a few contacts in the flat cable that connects the T-Con board to the screen with some tape. It worked for a while and now out of the blue it turned into what you can see in the pic. I was able to get my hands on a known good T-Con board but the problem still persists. Now, what I've noticed is that the cooper colored flat cables that are directly connected to the screen itself are very hot to the touch...
          09-15-2022, 07:48 AM
        • ItalianSat
          LCD SAMSUNG LE40A656A1CXXE - Vertical Lines on Half of The Screen?
          by ItalianSat
          Hello Everybody,
          I have a 40 inch LCD SAMSUNG LE40A656A1CXXE. Its problem is that there are Vertical Lines on Right Half of The Screen.
          Interestingly enough, when I move my mouse (in the case if connected to a PC) or when I am watching the TV, lines also move. At first appearance, I had thought that the problem might arose from loose vertical ribbons (COF), but when I opened up the TV for further investigations, I realized that the problem cannot be solved by touching them.
          Moreover, I detached the T-CON board for a new round of investigation. I personally...
          06-28-2022, 06:02 AM
        • Firentiosi
          1/3rd of screen black with occasional vertical lines - repair attempt for learning! - Kogan KALED58RT9220SVA
          by Firentiosi
          Thanks for offering your assistance with this. I'm an electronics enthusiast with moderate level of competence (have a decent lab with two power supplies, microscope, DSO, hot air, good iron, can competently work at a component level on SMDs, design and solder own PCBs etc). I really enjoying fixing things and learning new stuff so took up a free 58" LED TV and have been googling and watching Youtube videos to see if I can fix this! I am happy to go down to individual component replacement/strip replacement etc - it's all in the name of learning.
          The issues are as follows: the...
          11-27-2024, 12:33 AM
