Philips 42PFL7403D 42" TV
  • Bitfix
    • Aug 2016
    • 5
    • Norway
    Hello my learned friends. (hope that doesn't sound too tacky)
    My TV a Philips 42PFL7403D developed a problem with the screen flickering and sometimes taking several attempts to switch on.
    I whipped the back cover off to check out my suspicion of one or more bad caps, and staring me in the face, there it was on the power board, cap number 2111: a 330uF 200V Lelon REA 85C. Unmistakably bulging at the top.
    Here in Central Norway we are not exactly tripping over electronic component suppliers, but we managed to locate one local guy who does some odd repairs.
    He had a Nippon Chemi-Con 330uf 400v in stock which had the same 10mm pin pitch but the can itself was almost twice as high. I fitted it, but then the TV would not come on at all. I then proceeded to refit the old bulging cap and boom it fired up again, albeit with the blinking fault
    My question is this. Why would that replacement cap not work? the original was rated at 200v but the replacement was rated at 400v.
    Needless to say I fitted it with correct polarity. Is it possible the new one was duff (I don't have a cap tester) or do I need to buy another which is rated at 200v
    Thanks in advance for any help.
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Philips 42PFL7403D 42" TV
    Unless the capacitor has a high ESR I don't see why it would not work. Can't you order a replacement through ebay?
    • Bitfix
      • Aug 2016
      • 5
      • Norway
      It's quite a mystery to me. All the other caps look good.
      Yes I'm going to order a replacement online, but was just asking beforehand to see if anyone had any additional insight, as if I have to wait several days for delivery it would be good to get everything together. I don't see what else it could be other than that, so I guess I'll just go ahead and order the replacement and hope for the best.
      Thanks.
        Some other caps that may not show the sign of bulging tops can be bad too.
        • Bitfix
          • Aug 2016
          • 5
          • Norway
          Yes indeed Budm, that is quite true, and I intend to swap at least 3 other 'startup' caps in the process too. Fortunately we have those lying around the workshop, it was just this larger, bulging cap which was the problem to get hold of.
          But I sincerely thank you for the reminder / tip and also the links provided.
          I ordered the 330uf 200v cap and when it arrives on Tuesday 30/08/16 I'll fit it (before the other 3) and when the job is complete I will post the results just in case it may benefit someone else at some point.
          Thanks.
          • Diah
            • Feb 2013
            • 6614
            you need to tell what blinking code you get after your replace the original cap in set !!
            did you know about Philips SDM ?
            • Bitfix
              • Aug 2016
              • 5
              • Norway
              Ok Diah, I'll be sure to do that.
              • tuner2000i
                Philips 65PUS8518/12 distorted image after main board replacement
                by tuner2000i
                hello everyone,
                I don't normally do tv repairs but this is a case with my personal TV which got fried together with many other electronics in my house after a thunderstorm.
                The TV is a Philips 65PUS8518/12 which had no power. I measured and concluded that the main board was probably fried through ethernet or hdmi. I found a board with same number 715GD328-M0F-B00-005Y (I had G) but from a 55PUS8518. The TV starts but the image is doubled, distorted. I need to set the panel code which is 016 according to the sticker on the back but I can not seem to do it.
                07-15-2025, 01:15 PM
              • Rauni
                Philips 58PUS7805/12 showed no picture; after T-Con replacement, shows halo
                by Rauni
                Hello, this is my first post on this forum, and my first attempted to repair a TV.
                My Philips 58PUS7805/12 stopped working recently. It is not that old, about 5 years. We were on a trip for a few days and when we came back, it had stopped working out of a blue (Perhaps our house was hit by a lightning strike? Don't know.)
                Read from a guide that I should test if the screen shows picture with one of the T-Con cables disconnected. Did that, it showed perfect picture (first on left, later on right side).
                Read also that we should test what happens if we...
                10-01-2023, 12:06 AM
              • Pulka
                Philips 32PFL3605/12 U4201 replacement
                by Pulka
                Hello everyone!
                This is my first post, but not my first attempt to repair a TV.
                So a few days ago I got this Philips TV (TPM4.1E LA), which produced weird symptoms.
                There were no 12 and 24V, which was caused by a shorted schottky. I replaced that, the voltages are alright everywhere, but it still refused to turn on or even produce a standby light.
                Thats when I removed the cover lid from the U4201, turns out that it badly burnt through, thanks to that replaced diode. It's an MTK MT8222TMMU, and I already found a replacement for it. However in the service...
                12-29-2021, 01:51 PM
              • Tynan Dill
                by Tynan Dill
                Assuming...
                11-22-2024, 01:46 PM
              • Sharpa
                Repair attempt Philips 55OLED804/12
                by Sharpa
                I bought a SH Philips 55OLED804/12 TV with known defect in an attempt to repair it for personal use.
                The symptoms when bought: Philips logo appears then tv turns off
                Things tried so far:
                1. Powering it on: Philips logo shows on the screen, sometimes with some minor artefacts then shuts down. Red status led flickers rapidly into two batches then repeats
                2. Put it in recovery mode by pressing joystick down then plugging it to mains: The tv shows the logo then shows the android animation along with some minor artefacts on the screen...
                11-22-2025, 08:30 AM
