Help! Cap on Y-sustain went poof after main board swap
  • Kjelds
    • Aug 2016
    • 30
    • Denmark
    Re: Help! Cap on Y-sustain went poof after main board swap
    Received my Y-sus board today. Just checked the y-buffer board by doing this test: https://www.youtube.com/watch?v=51SZsfH60EY
    There wasn't any indication of shortages of the IC's when checking between the Y-sus outputs and the Y-buffer outputs. Are there any additional tests, that I should do?
    If not, I'll swap the Y-sus board and then check if Vs, Va, Ve and Vsc all match the sticker on the back of the TV. Are there any additional tests I should do to ensure, that my TV doesn't blow up again
    • Kjelds
      • Aug 2016
      • 30
      • Denmark
      Made two identical posts, how do I delete this?
      • Kjelds
        • Aug 2016
        • 30
        • Denmark
        So I've looked through a couple of videos explaining how to change the Y-sus and decided to give it a go.
        After the swap the TV seems to work perfectly again. I've checked all the voltage testpoints (Vs, Va, Ve and Vsc) and they are all pretty much in line with the label on the back, only off by max 0.5 volts, which seems to be decent in the videos I've seen.
        So hopefully it will now keep working for more than 24 hours.
        If any of you have suggestions to what I should check before I put the TV back on the wall, it will be greatly appreciated as all your previous suggestions which seems to have fixed the problem
        • vinceroger69
          • Mar 2012
          • 6714
          • uk
          Hi just saw your update im glad the replacement y-sus has solved your issue i still wonder why your old one blew though, but glad the tv is now working fine, do a long soak test on it turning it on and off also then after a few days im sure you can class this set as a sucesfull repair.
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Awesome work
            • Kjelds
              • Aug 2016
              • 30
              • Denmark
              #26
              Hi Vinceroger69,
              Just for a newbie like me, what do mean by soak testing? Just leaving the TV on for several hours or what?
              Thanks again for the good advice and link to the board
              • vinceroger69
                • Mar 2012
                • 6714
                • uk
                #27
                yes thats what most of use do after a repair like you have done, turn it on and off too during the day a couple of times like in normal use and also leave switched on for a good few hours doing this soak test also rules out any overheating issues etc that only show up when tv is hot.
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  #28
                  I run the Tvs I have repaired for 24 hours solid downstairs running test patterns.
                  • Kjelds
                    • Aug 2016
                    • 30
                    • Denmark
                    #29
                    Great! I'll do that, when I get home from work
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      #30
                      As its your own Tv just watch it normally if it goes wrong its right in front of you
                      • Kjelds
                        • Aug 2016
                        • 30
                        • Denmark
                        #31
                        Yeah, last time I did that, it blew up, but I guess there's no other way fingers crossed
                        • cheeky2
                          by cheeky2
                          05-25-2024, 03:27 AM
                        • Dani_2024
                          by Dani_2024
                          10-28-2024, 05:06 PM
                        • Asraf Atb
                          Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
                          by Asraf Atb
                          Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
                          Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
                          I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
                          01-27-2025, 05:02 PM
                        • JSin21
                          Compatibility of main boards between different variations of samsung MU6100
                          by JSin21
                          Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
                          I have Samsung Smart TV UA65MU6100WXXY version DA01
                          Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
                          11-27-2023, 04:54 AM
                        • jb_Bak
                          by jb_Bak
                          CN6401
                          Pin 01 NC
                          Pin 02 NC
                          Pin 03 "BL_ON": 0V
                          Pin 04 "N/C"
                          Pin 05 "STBY 3.3V": 3.5V
                          Pin 06 "GND": N/C
                          Pin 07 "AC_OFF"...
                          09-27-2021, 04:52 PM
