Panasonic TC-P50U50 - SS Board repair
  • StephenU
    • Dec 2013
    • 230
    • United Kingdom
    Hi guys im looking for some help with regards to the TNPA5623 SS board on this set, would it be possible to use a DG301 an place of the DG302 (Q051) TO-220 package Transistor?
    Or does anyone know where in the UK I can source an equivalent or original.
    (( ....or does anyone have any spare lying around i could possibly purchase from??))
    Thank in advance
    Stephen
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Re: Panasonic TC-P50U50 - SS Board repair
    I've bought from and had no problems with the following UK supplier who have DG302 in stock.
    http://stores.ebay.co.uk/SWLElectron...p2047675.l2563
    • StephenU
      • Dec 2013
      • 230
      • United Kingdom
      Thanks Dick,
      They only seem to have the TO-263 package in stock, I need the TO-220 package.
      (( http://www.ebay.co.uk/itm/DG302-TRAN...item2cae3ed76e ))
      Rgds
      Stephen
      • tw2005
        • Oct 2011
        • 6458
        FGPF4536 ,
        301 will be 5Amps lower rating than the 302
        What other bits do you have around ? DG402,502? RJP43F4?
        • tw2005
          • Oct 2011
          • 6458
          http://www.chsinteractive.co.uk/sear...y=dg3d3020cvlw
          • StephenU
            • Dec 2013
            • 230
            • United Kingdom
            Originally posted by tw2005
            FGPF4536 ,
            Hi tw2005,
            I have the guts of another Panasonic unit, think its a 42" though, I'll look on those boards and see whats there, i have loads of Samsung stuff if you think i might be able to salvage it from there?
            • StephenU
              • Dec 2013
              • 230
              • United Kingdom
              FGPF4536 ,
              Found this :
              http://uk.rs-online.com/web/p/igbt-transistors/8070789/
              • dick_barton
                • Aug 2015
                • 6642
                • Wales
                I've also ordered from this company and received the items in less than 48hrs which is why I made a note of them. They were faster than UK Royal Mail.
                http://www.ebay.it/itm/DG302-Transis...item542f474d64
                Edit
                I did pay for TNT delivery
                • tw2005
                  • Oct 2011
                  • 6458
                  Originally posted by StephenU
                  Hi tw2005,
                  It's a 45A with 250A peak pulse . maybe even try a 45G128 toshiba but I think that fairchild one would be handy at 50A and 360V rating or spend the coin and get original anything from china I'd expect to be too cheap and not the real item.
                  On the US sites it appears restricted sale,only for service centres
                  • tw2005
                    • Oct 2011
                    • 6458
                    So did I but there is a problem
                    Discontinued product
                    • StephenU
                      • Dec 2013
                      • 230
                      • United Kingdom
                      found this, tw2005 this all good to use, have you used this before?
                      http://www.ebay.co.uk/itm/RJP43F4A-T...EAAOSwvU5XNIIr
                      • tw2005
                        • Oct 2011
                        • 6458
                        I've never worked on a 2012 model or done a SS board like this so no.
                        Done plentyof SC boards and experimented with a few subs on some without any issues.
                        If you have nothing handy and ordering , why not just get the right one? The RJP43F4 should work but I'd go for the Fairchild FGPF4536 if i was going for a sub and getting it in.
                        Only suggested a whole bunch of others in case you had one or a board to salvage from
                        • StephenU
                          • Dec 2013
                          • 230
                          • United Kingdom
                          No problem thanks for your time tw2005,
                          S.
                          • m1ch43lzm
                            by m1ch43lzm
                            05-12-2025, 08:37 PM
                            by sam_sam_sam
                            After all of...
                            07-13-2024, 08:14 PM
                          • canadaboy25
                            Panasonic TC-P54VT25 No image. A or D board?
                            by canadaboy25
                            I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
                            The panel is primed as there is a slight glow from the entire panel. This means the problem should be logic related. The service manual also confirms this and recommends replacing the A or the D board.
                            I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
                            01-17-2021, 01:06 AM
                          • howardc64
                            by howardc64
                            Yesterday, 05:17 PM
