Swapping out LG Plasma mainboard - PC42S5
  • ocf
    • Jun 2016
    • 157
    Hello fellow badcapers,
    I have found a mainboard replacement for the LG TV I am having issues with. Any mainboard flexing or vibrations set of complete corruption of all TV menus and graphics.
    Replacement board -
    http://www.lcd-plasma-parts.co.uk/bn...?search=00582b
    The board above states its from TV model number PC42S5H
    My TV has following model name and type number on the back - 42D5S PC42S5
    I can see that the board will fit and has same connectors, it has some additional inputs that are covered on my chassis, this wont be an issue as I can cut out the plastic sheet used to blank out the ports.
    I have a fairly in depth schematic and adjustment guide for this model, it states that when changing the mainboard ATM Channel fixing and White balance adjustment need to be performed.
    To do this I need access to the service menu.
    I don't have the original remote, any way to get around this and access service menu for these adjustments if they are needed?
    thanks guys
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Swapping out LG Plasma mainboard - PC42S5
    http://openlgtv.org.ru/wiki/index.ph..._menus_/_modes
    • ocf
      • Jun 2016
      • 157
      Thanks buddy, that looks perfect.
      I've ordered the board, I will keep you posted!
      • SACR
        Panasonic Plasma TH-P42X28K A-Board @ Mainboard Schematic needed
        by SACR
        I need Schematic A-Board @ Mainboard for Panasonic Plasma TH-P42X28K. Code : TNPH0842. I want to replace 1 MLCC but I don't know values (capacitance & voltage) & codes. Can someone help me? Thank you...
        11-20-2023, 11:53 PM
      • Mark R
        Marantz Model 150 Tuner "NULL" Adjustment..
        by Mark R
        I am not ashamed to say this is my first FM alignment I have ever done. I am well versed in electronics and repair. Been doing it for many years on Pro Audio Live sound equipment. Worked on Power amps EQ's musical gear and Large format Mixing Live consoles Etc. But now I can see this is a whole different world when it comes to tweaking this kind of gear. I do have the proper gear like the SENCORE SG 80 and HP Generators and Scopes Etc.
        Look below at Adjustment 12:8. The Null adjustment. I have a Heathkit IM-28 VTVM that was rebuilt and has new Burned in tubes that I used for this...
        12-30-2024, 03:18 PM
      • Mirenia
        Dell Latitude 7420 - Touchscreen not working since Mainboard replacement
        by Mirenia
        I've got a little "problem child": my Dell Latitude 7420 2-in-1, which had a faulty mainboard.
        I replaced it, but ever since, the touchscreen no longer works — and honestly, I’m running out of ideas…
        In Windows Device Manager, I just see an I2C HID Device with error code 10. Sporadically, the touchscreen is recognized correctly for just a few seconds, but I haven’t been able to determine under which circumstances this happens.
        The touchscreen also doesn’t work in UEFI/BIOS, although it’s enabled...
        03-30-2025, 06:47 AM
      • orcic
        MASTER TL240 and new mainboard LW36BKC01
        by orcic
        I have an old MASTER TL-240 LED TV. Since it stopped working and it had a DVB-T receiver that is being dismissed in Italy, I've decided to replace the mainboard with a DVB-T2 one.
        The original problem was that when switching on the TV, the power LED was transitioning from red to steady blue, without showing video or audio.
        After checking some voltages on the power supply board (HKL-240101-B Rev. 1.4, HKL from now on) someone suggested me to replace the mainboard.
        Now I have some doubts about how to connect the new mainboard to the old power supply.
        First of...
        05-12-2023, 08:10 AM
      • Devonavar
        Vizio M43-C1 - How closely do I need to match the mainboard number?
        by Devonavar
        I have a Vizio M43-C1 stuck in a reboot loop with no backlight.
        I've tested all the voltage rails coming out of the power supply and they are "normal" for this model (PS_ON & DIM go high when turned on, BL_ON & 3D_ON are close to zero due to backlight power flowing through the mainboard, 5VSB is 5V, and 12V is 19V, which is apparently normal for this board).
        Basically, I get similar results to Garry in this post: https://www.badcaps.net/forum/showthread.php?t=80346
        So, I've ruled out the PSU for now.
        The reboot loop...
        08-14-2022, 08:46 PM
