LG LED 60LS5750 - T-Con Question
  • SullyE
    • Dec 2015
    • 21
    Hi Guys,
    Me again. So I picked up a 'nice' LG LED Smart TV (model above) a couple months back that had a scrambled video... but audio was fine. Forgive me if I posted this already.
    I reflowed the main BGA (IC201) and that 'resolved' the issue. I was happy, until last night. Something went on the T-Con again (I think) as I've gotten the same failure back, scrambled video (audio ok).
    Doing some digging... I found the original T-Con board (Sharp) P/N RUNTK5119TPPZ can be replaced with a Vizio (Sharp) RUNTK5261TPZC T-Con. This is according to ShopJimmy.
    https://www.shopjimmy.com/sharp-runt...-con-board.htm
    Has anyone done this??? If not, I guess I'll be the guinea pig here because I ordered one this morning.
    Back when I first got the tv, I checked Ebay for replacement T-Cons (under P/N RUNTK5119TPZZ) and found a seller the had the 5261 listed as 'an upgraded version' of the original 5119, that can be used in the LG 5750, 5700 and a couple other models.
    Thinking out loud here... I believe this should work, but thought I'd ask some of you guys on here that may have more experience.
    Any info you could provide would be appreciated. I'll post back with results after I install it. It 'should' be fine. Hopefully!
    Thanks much,
    Gregg
  • SullyE
    • Dec 2015
    • 21
    Re: LG LED 60LS5750 - T-Con Question
    I guess no one's tried this, or heard of trying this replacement T-Con board then.
    I haven't gotten to replacing it yet... but found something kind of interesting. When the inside house temp gets to be 75 F, the TV 'acts up' and starts flickering and gets random vertical bars in it, audio is fine. If we shut it off... wait 10min or so, while the A/C runs (turning the thermo to a 'cooler' setting)... it's fine! It's repeatable too!
    We had warmer/humid weather here about a week ago here in the Midwest, and that's when it started acting up. I know T-Cons are known for causing a wide range of issues in different makes/models of TVs... so I hope that's it. I can't see it being the panel, otherwise it wouldn't be this intermittent and repeatable, if that makes any sense.
    • mmartell
      • Oct 2013
      • 3189
      A better way to find out if it's repeatable is to use hot and cold air directly on the board. Have you tried adding a heatsink to the ic, if it doesn't have one already ?
      • kca
        by kca
        Hello all ~
        08-31-2025, 06:38 AM
        Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
        This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
        I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
        I am comparing them to a brand new one that I installed
        The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
        I going to let it run for several days before I remount back on the wall next to the...
        09-05-2024, 06:48 PM
      • netgearnetgear
        TCL 43S423 TCON OR PANEL FAULTY???
        by netgearnetgear
        Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
        08-20-2025, 06:04 PM
        HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i7-9700 Specification for Upgrade or Repair
        This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
        09-12-2024, 02:30 PM
        HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i5-9500 Specification for Upgrade or Repair
