Toshiba 46L5200U good picture for 10 minutes then the picture goes black.
  • nwcs
    • Dec 2015
    • 311
    • usa
    This tv will have a good picture for about 10 to 15 minutes no problem when there is some video source but if you remove the video source the picture will stay on for at least a half hour and most likely longer, just have not tried it longer. When the backlights go out I loose all voltages from the led driver board to the led's. The power supply does still provide the 24v and the backlight on stays at 3.5v so I know it is either a bad led driver board or maybe a led causing this issue. I do know that if I remove the power for the led's from the led driver board the led driver board voltages drop to almost nothing. I did replace the led driver board with one from Ebay but pretty much the same issue so I do not know if I got a good one or not. I really hate removing the lcd panel from these but it may come down to that to check the led's. I have had this same model in the past with the picture flashing and then led's shut off and that was a led driver board. I welcome any ideas at this point.
  • CapLeaker
    Leaking Member
    • 8182
    Re: Toshiba 46L5200U good picture for 10 minutes then the picture goes black.
    an LED going bad? The LED power board can sense that something is wrong. If there is something wrong, then it will shut down. Maybe decrease your backlights almost next to nothing and see if the backlights stay on longer...
    • nwcs
      • Dec 2015
      • 311
      • usa
      i will try that and see what happens
      • nwcs
        • Dec 2015
        • 311
        • usa
        Thanks CapLeaker, that did the trick. Ran all day without going black.
        • CapLeaker
          Leaking Member
          • 8182
          yw. One of the LED's is failing. So you'll be talking it apart sooner or later to replace it. Anyhow, you know what the issue is now.
          • nwcs
            • Dec 2015
            • 311
            • usa
            Well it ran for two days ok and the picture went out so I took the lcd panel off and inspected the led's. They all light up fine but the connector looks to have a burned mark on it. I am going to try and repair this.
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              That's another area of weakness with led sets that the interconnections are often of poor quality and bridging them by soldering jumpers removes that problem from re-occuring.
              • nwcs
                • Dec 2015
                • 311
                • usa
                That's a good idea. I will try that
                • comptek
                  • Aug 2013
                  • 606
                  had that on a edge lit tv before the connecters looked like they were off a cheap radio or something burnt and melted bridged and all ok the led driver detects current going up and cuts out
                  • nwcs
                    • Dec 2015
                    • 311
                    • usa
                    The only problem I am having at this point is getting the connector off so I can bridge the connections.
                    • nwcs
                      • Dec 2015
                      • 311
                      • usa
                      Well tried to remove the old brittle connector on the led strip and it snapped off so I just ordered a new one from shop jimmy.
                      • Mgiffune
                        by Mgiffune
                        06-09-2024, 10:28 AM
                      • Jne2016
                        toshiba tf-43a810u21 flickers/shakes but with good picture
                        by Jne2016
                        Anyone have any experience with these tvs I just got this tv off marketplace and the screen will flicker/ shake for a couple seconds than stop then repeat.
                        I tried fact reset but it can't get past searching for remote even though I have 2 remotes that work for it. Now initially the screen wasn't shaking at all after factory reset intill it got to searching for remote and it was taking for ever so I turned it off and back on and it started to do it again.
                        Is this a hardware issue or a board?...
                        10-13-2024, 09:01 AM
                      • jord4231
                        Toshiba 37AV500A Regza TV good power supply no sound no picture
                        by jord4231
                        Hi Everyone,
                        I'm working on a Toshiba 37AV500A Regza TV.
                        The issue:
                        TV was working picture and sound went out. Green stand by light stayed on, It will respond to the power button being pressed (goes in and out of standby)
                        The TV will very intermittently work for around 40 mins then stop. This doesn't seem to matter if its hot/cold unplugged for a while etc.
                        I checked the PSU voltages and everything looked good.
                        No bulging caps or signs of heat.
                        24v aud = 24.41v
                        12v = 11.98v
                        5v = 5.062
                        p_o/f = Goes high...
                        03-29-2022, 09:21 PM
                        09-06-2024, 05:33 AM
                        Toshiba Portege R30-C Notebook Specification for Upgrade or Repair
                        This specification for the Toshiba Portege R30-C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the R30-C boardview and R30-C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba Portege...
                        09-06-2024, 05:30 AM
